EEPROM help
Results 1 to 6 of 6
Thread: EEPROM help
    Jul 2004
    CA
    Default EEPROM help
    Why is it that Writing to EEPROM takes longer than reading from EEPROM.
    Writing a BYTE to EEPROM takes around 4ms with a 20Mhz, While READING a BYTE from EEROM takes like 3 microsec.
    cant explain why this is the case. any way I can reduce the time it takes to write to EEPROM?
    srig
    Are you talking about the internal EEPROM of a PIC or an external one?
    If the internal one, how did you measure it? By interrupt or by testing with pauses?
    Are you using WRITE and READ ? If so what about if you use some assembly lines (they're mostely provide in datasheet)
    Some external can be much faster than this IMO.
    Jul 2004
    CA
    I am using the WRITE and READ command in the pbp compiler. I us MPLAB , where you can actually debug your code line per line and to see how long each command takes. by using the stopwatch, embedded in the GUI. and that is pretty well calculated timing they use. anyway I was just curious on why it takes soo long to write .. then read.. becasue I am noticing flickering at the output because of this. was wondering how I can get around this.
    please help!!
    srig
    what is your actual code ?
    Feb 2004
    Germany
    I guess it's more a matter of "physics" than a matter of coding.
    I'll try to dig out a document that explains it (if I find time to)
    regards
    Ralph
    Look in the datasheet for the device you're using.
    Electrical Specifications
    ....DC Characteristics
    ........ Data EEPROM Memory
    EEPROM Erase/Write cycle time is from 4 to 8mS. No wait time for reading. Just erase & write.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
  1. Can't read sequential addresses in external EEPROM
    Last Post: - 18th February 2010, 15:46
  2. How to define constants that specify eeprom addresses
    By DwayneR in forum mel PIC BASIC Pro
    Last Post: - 8th December 2009, 05:07
  3. Problem with I2C EEPROM addressing
    By Atom058 in forum General
    Last Post: - 3rd November 2009, 04:17
  4. How to write/read strings EEPROM/LCD
    By g-hoot in forum mel PIC BASIC Pro
    Last Post: - 11th February 2007, 07:26
  5. word variable to 25lc640
    Last Post: - 6th July 2004, 20:59
