Hi there,
I'm using MCS+ ICD and it just stops on the fourth command. For instance, in the code below the ICD will freeze on "porta = %00000000". If I rem that line out it will freeze on the next and so on.
The program runs fine without the ICD running.
Does anybody have any ideas?
'Defines
define OSC 20
define LOADER_USED 1
trisa = %00000000
trisb = %00000000
trisc = %00000000
porta = %00000000
portb = %00000000
portc = %00000000
'Variables and Constants
counter var word 'For-Loop variable
servo var byte 'Servo output pin
'servo = portb.5
'Servo movement module
spin_CCW:
counter = 0
for counter = 1 to 100
pulsout portb.5, 150
pause 20
next
spin_CW:
counter = 0
pulsout portb.5, 1500
pause 20
next
goto spin_ccw
