Please explain me WHY!
Results 1 to 7 of 7
    Default Please explain me WHY!
    I am using PIC16F690.
    I am wondering why when I use the following program:
    intcon=0
    cm1con0=0
    cm2con0=0
    ansel=0
    anselh=0
    trisc=0
    portc=0
    define OSC 4
    option_reg = %00001000
    high portC.0
    high portC.1
    high portC.2
    high portC.3
    low portc.0
    low portc.1
    low portc.2
    low portc.3
    All leds connected to PORTC work as expected.
    AND why they don't work when I use the following code:
    intcon=0
    cm1con0=0
    cm2con0=0
    ansel=0
    anselh=0
    trisc=0
    portc=0
    define OSC 4
    high portC
    low portC
    Try adding this to your loading values:
    trisC = %00000000
    This will set your portC as outputs.
    The zeros fromleft to right are portC.7, portC.6, portC.5, portC.4, portC.3, portC.2, portC.1, portC.0.
    You can changed the 1's or 0's depending on what you want them to be. In your case, all zeros for outputs.
    or
    'add your stuff here'
    trisC = %00000000
    PORTC = %00001111
    PORTC = %11110000
    Goto Main
    for tris, 0 is output and 1 is input
    Quote Originally Posted by financecatalyst View Post
    intcon=0
    cm1con0=0
    cm2con0=0
    ansel=0
    anselh=0
    trisc=0
    portc=0
    define OSC 4
    high portC.0
    high portC.1
    high portC.2
    high portC.3
    low portc.0
    low portc.1
    low portc.2
    low portc.3
    intcon=0
    cm1con0=0
    cm2con0=0
    ansel=0
    anselh=0
    trisc=0
    portc=0
    define OSC 4
    high portC
    low portC
    Can't tell you why, except <b>maybe </b>it's not supposed too, You CAN do this:
    PortC = 255
    PortC = 0
    Put ADCON0 = 0 in to disable the A/D converters too
    Sep 2009
    Hi.
    Joe and Marc told you what to do to get desired result, I'll only add that the reason behind it is: high & low are commands that work with one pin you specify not the whole port...
    CMCON = 7 will tuen off the comparator module, if your chip has this.
    Can you post a picture of your project? It would be nice to see how you got everything setup.
    Wink
    Would be interesting to compare the produced asm code with " High PORTC " vs " High PORTC.1 " ...
    Explanation is nowhere else ...
    I Still haven't found a use for the first one ... Performs some kind of Read then Write Port sequence.
  1. i need more explain
    By lo0oly in forum mel PIC BASIC Pro
    Last Post: - 13th April 2009, 14:55
  2. 16F676 Please explain this problem...
    By Jayhovah in forum mel PIC BASIC Pro
    Last Post: - 9th May 2008, 22:30
  3. Replies: 8
    Last Post: - 14th April 2008, 07:58
  4. Please explain about this program
    By wafagenius in forum mel PIC BASIC Pro
    Last Post: - 10th October 2006, 02:25
  5. Please explain PORTB.0[i]
    By blainecf in forum mel PIC BASIC Pro
    Last Post: - 2nd July 2006, 02:31
