hserout PIC pic 16F876
Results 1 to 8 of 8
    Question hserout PIC pic 16F876
    Hello !
    I would like to know if , using the define and the HESROUT instruction, it is possible to change the baud right *during* the execution of the program.
    I would like to make possible the user [ me , "8-) ] to select 9600 and 19200.
    Everything is ok in both speed, but i can't switch from one to another ...
    It seems that new define are not allowed during execution ...
    And writing to regsiter seems to confuse HSEROUT ...
    If someone has an idea or a piece of could, i would be glad to read it / him
    Thank a lot for helping !
    Apologize for poor english , i was a bad boy at school ...
    Vincent
    Vincent
    don't be afraid of that...
    can you something for me. I'm not sure it's gonna work but... worth a try
    Let's assume you have a 20MHZ crystal.
    Refer to the table 10-4:
    SPBRG=129 '@9600 bauds
    SPBRG=64 '@19200 bauds
    IMO we can change the baud rate only by changing the value of the SPBRG register.
    so give a try to this snipet
    DEFINE OSC 20
    start:
         TXSTA=$24
         RCSTA=$90
         pause 100 'try to remove this pause after
         HSEROUT ["comm @9600 bauds"]
         TXSTA=$24
         RCSTA=$90
         PAUSE 5000 'wait 5 seconds
         HSEROUT ["comm @19200 bauds"]
         goto start
    let me know... i'm curious.
    If it's working, try to define TXSTA and RCSTA only one time at the begining to see if it's also work.
    DEFINE OSC 20
         TXSTA=$24
         RCSTA=$90
    start:
         goto start
    Post
    There should be no problem to switch between theese two baudrates "on the fly". All you need to do is put correct values in the SPBRG register(and perhaps bit BRGH in TXSTA). There is a table specifying SPBRG values at diffrent oscillatorspeeds. I can't help you further without knowing what crystal you're using.
    Hello,
    thanks for helping,
    my XT is a 4MHz , i will adapt value, and try what you suggest , i will let you know the results.
    Vincent
    Thumbs up
    Hello,
    steve you are the king, your code works both 1 and 2 !
    To share my experiment :
    I did not use anymore the define, but i write to TXSTA and
    RCSTA , i only use the autoerror clearing define, and it is ok.
    The pause 100 after the change of SPBRG , is mandatory, probably the baud clock needs to get stable , without this pause the first char are lost ( maybe , 3 or 4 character at full speed simple serout like :
    hserout["ABCDEFG"]
    with 100ms pause, you are secure, and it is only at "initialization" not after.
    Many thanks for your help, switching the baudrates has been a big moment for me !
    Vincent STEINMETZ
    (France , other side of sea ... )
    Salut Vincent!
    Great to know it's working fine now. I don't know how the *initialisation* must be, but if you can try with some other low value like
    PAUSE 10
    PAUSE 1
    PAUSEUS 100
    PAUSEUS 10
    PAUSEUS 5
    @ NOP ' 1usec delay @4MHZ
    will be interesting to have the results...
    Default ini
    Hello steve,
    I have done the tests
    the minimal pause seems to be pause 10 , under this value , the three first character are lost, every time , it is not erratic but highly repeteable ...
    =>I have 20Mhz pic working at 4mHz
    Let me know if you need something else.
    Vincent
    That's perfect. Was for learning purpose. Great to know that.
    thanks.
  1. I2C Slave with a PIC
    By ralfmayr in forum mel PIC BASIC Pro
    Last Post: - 21st August 2016, 17:44
  2. HSEROUT and Commas, What? Help Me Understand
    By altech6983 in forum mel PIC BASIC Pro
    Last Post: - 20th July 2009, 19:12
  3. HSERIN & Interupts (aka controlling PIC programs from a remote PC)
    Last Post: - 17th June 2009, 14:46
  4. Is HSEROUT corrupting bit 7 ?????
    By Robert Wells in forum mel PIC BASIC Pro
    Last Post: - 23rd October 2008, 16:26
