2.60 + MCSP problems
Results 1 to 15 of 15
    Thanks for the reply Alain,
    I'm not really using MPLAB, I only have it installed to get MPASM so the language pack etc shouldn't matter since I'm not running PBP from inside MPLAB, should it?
    Both MPLAB and PBP are installed to their default locations, C:\PBP and C:\Program\Microchip\MPASM Suite. They weren't at first since it has always worked before but I removed and reinstalled to their default loactions so now they are. And I have pointed MSC+ manually to BOTH the PBP folder and the MPASMSuite folder but it's still the same.
    PS. C:\Program is the default on Swedish WinXP while it is C:\Program Files on English versions.
    Do you also get an NTVDM error?
    See the images ...
    http://www.pbpgroup.com/files/MCS_Error/MCS_Error.htm
    Notice the second and forth images.
    Hi Darrel,
    No, as of yet I haven't. I get exactly what you have in the 2nd and 4th screenshot. And, as I said I've pointed MCS+ to the PBP and MPASM folders manually.
    Thanks!
    OK, that's good, I think...
    The problem comes from not being able to run programs in a 16-bit Virtual Machine.
    And there seems to be several reasons why it can happen.
    Here are two tests recommended by Microsoft ...
    Open the run command line (Start | Run) or WinLogo+R.
    Enter the command sysedit.
    If it does not start the system configuration utility ... it may still be an NTVDM error.
    If it does start, try to open edit.com from the Run command line.
    If it can not open the editor, it may be a Windows on Windows problem.<hr>
    In my case, when I took those images, I had a problem with one of my video cards, and the driver was causing problems.
    After replacing the video card and installing the new driver, the problem magically disappeared. But there can be many causes.
    I had 2.50 at the time, but it's a Windows/MCS problem, not a PBP problem.
    You can still compile from the command line or with a batch file.
    (As long as there isn't an associated .pif file).
    Hi Darrel,
    Both the System Editor and the edit.com starts fine from the Run command line.
    "Nothing" have changed on the computer except installing v2.60 and there's nothing strange in the device manager.
    Crap, first a 5 week waiting time to get 2.60 and now this....guess I'll have to resort to the old command line compile then. I haven't tried un/reinstalling MCS+ yet, I'll do that and I'll also try on another computer tomorrow.
    Hi, Henrik
    Stupid question, I know ... but ...
    Is yout Win XP up to date ???
    BTW ... why not launch the PBRegister.bat file ( in the PBP folder ) ???
    fixed some issues for me !
    Hi Alian,
    Yes XP is up to date - it worked fine with 2.47 but after installing 2.60 it's a no-go.
    I don't seem to have a file called PBRegister.bat, only .bat file I've got in the PBP directory is PBPMPLAB.bat which is supposed to be used when running PBP within MPLAB - which I don't.
    Question
    Strange ...
    Here it is.
  1. MCSP, PBP260, Win7 - is it impossible?
    By HenrikOlsson in forum General
    Last Post: - 26th January 2010, 18:08
  2. MCSP - Cannot find include file
    By Andy Wood in forum mel PIC BASIC Pro
    Last Post: - 21st January 2008, 02:37
  3. MCSP Loader Problem pls help
    By Nestyplus in forum General
    Last Post: - 17th February 2006, 05:07
  4. Problems with 16F876 on interrupts an WRITE / READ
    By BigWumpus in forum mel PIC BASIC Pro
    Last Post: - 20th December 2005, 15:38
  5. Replies: 1
    Last Post: - 31st August 2005, 21:00
