MCS+ ICD Freezes
Results 1 to 11 of 11
    mslaney's Avatar
    mslaney Guest
    Default MCS+ ICD Freezes
    Hi there,
    I'm using MCS+ ICD and it just stops on the fourth command. For instance, in the code below the ICD will freeze on "porta = %00000000". If I rem that line out it will freeze on the next and so on.
    The program runs fine without the ICD running.
    Does anybody have any ideas?
    'Defines
    define OSC 20
    define LOADER_USED 1
    trisa = %00000000
    trisb = %00000000
    trisc = %00000000
    porta = %00000000
    portb = %00000000
    portc = %00000000
    'Variables and Constants
    counter var word 'For-Loop variable
    servo var byte 'Servo output pin
    'servo = portb.5
    'Servo movement module
    spin_CCW:
    counter = 0
    for counter = 1 to 100
    pulsout portb.5, 150
    pause 20
    next
    spin_CW:
    counter = 0
    pulsout portb.5, 1500
    pause 20
    next
    goto spin_ccw
    i'm not sure of it but... what about if you switch your 2 first lines like this
    define OSC 20
    capitano's Avatar
    capitano Guest
    Post ICD
    Try
    Disable Debug
    define OSC 20
    trisa = %00000000
    trisb = %00000000
    trisc = %00000000
    porta = %00000000
    portb = %00000000
    portc = %00000000
    'servo = portb.5
    Enable Debug
    spin_CCW:
    counter = 0
    pause 20
    next
    spin_CW:
    counter = 0
    pause 20
    next
    goto spin_ccw
    mslaney's Avatar
    mslaney Guest
    niether change is working. Switching the defines didn't change anything and enable/disable debug times out when I click the ICD start button.
    ICD is working with most of my other programs as long as the main part of the program is within 4 lines of the chip registers and port init states.
    I'm using a 16F876A and compiling the program with that MCU in the drop-down. I've also tried changing OSCs and speeds in the .inc file.
    For example, the following program works ok with ICD:
    define OSC 20
    trisa = %00000000
    trisb = %00000000
    top:
    porta = %11111111
    portb = %11111111
    porta = %00000000
    portb = %00000000
    goto top
    Feb 2004
    Germany
    Mike
    you have already found the the solution to your problem.
    you just haven't realised it.
    The problem is with:
    trisc = %00000000
    the HWUSART TX and RX pins are on portc.6 and portc.7
    and you are setting RX (which is supposed to be an input) to output.
    This will stop the ICD from working
    since bidirectional communitaction between PIC and PC is no longer possible.
    with
    trisc = %10000000
    it should work.
    regards
    Ralph
    mslaney's Avatar
    mslaney Guest
    Hah!!!
    Thanks! Changing the tris reg. worked. This will fix 2 other programs that have brought me to my knees in frustration.
    Feb 2004
    Germany
    Hi Mike,
    good to know your problem has been solved.
    regards
    Ralph
    Red face
    why i didn't see it damn... seems i become older and my glasses need to be changed...
    Feb 2004
    Germany
    Hi Steve,
    it's probably just because your "favourite" chips
    (the ones you have plenty on shelf of)
    don't have HWUSART and Loader cabability.
    As long as you are able to solder SMD devices your glasses (and Health in general) are ok.
    regards
    Ralph
    Thanks ralph for the good words Looks like my glasses and my health are not so bad after all... SMD is much than easy to do.
    For the very first time in my life i did a mistake, and i'll have to live with it.
    LMAO!
    mslaney's Avatar
    mslaney Guest
    I thought I was wrong once but i was mistaken
  1. MCS Plus ICD with 16F88x; again!
    By ardhuru in forum mel PIC BASIC Pro
    Last Post: - 15th February 2010, 06:51
  2. DT Interupts and ICD?
    By ShaneMichael in forum mel PIC BASIC Pro
    Last Post: - 14th November 2009, 02:02
  3. ICD use with MCS Plus, PBPro & PicKit2??
    Last Post: - 30th September 2009, 23:06
  4. ICD Woes
    By spad13m in forum mel PIC BASIC Pro
    Last Post: - 14th February 2008, 05:56
  5. Another MSCP ICD question
    By keithdoxey in forum mel PIC BASIC Pro
    Last Post: - 31st July 2006, 00:07
