12F683 - how to set it to use external 4 MHz clock?
Results 1 to 20 of 20
    Sep 2009
    South Wales (UK)
    Hi there,
    Run into more problems now lol. With 'use mpasm' unticked, I can no longer use mplab ide to build/upload the file to the pic. It gives a stream of errors.
    However, if I tick the 'use mpasm' again, I get errors in picbasic pro:
    Warning[207] e:\.......\sertest.asm 93 : Found label after column 1. (device)
    Error[122] e:\.......\sertest.asm 93 : Illegal opcode (pic12F683)
    for code:
    @ device pic12F683, xt_osc, wdt_on, mclr_on, protect_off
    Include "modedefs.bas"
    OSCCON = %00001000
    ANSEL=0
    CMCON0=%00000111
    pw var byte
    led var gpio.4
    OSCCON=%01110000
    oldpwm var byte
    etc...
    I think I basically don't understand how these applications work together creating multiple files that are all linked together... I come from the old school - one program and run!
    Sep 2009
    South Wales (UK)
    oooh further to my last I think I misunderstood what you said Dave... so I switched to the:
    @ __config _XT_OSC & _WDT_ON & _MCLRE_ON & _CP_OFF
    and now the error I get in the compiler is Error[118] e:\....\sertest.asm 93 : Overwriting previous address contents (2007)
    Is this perhaps related to my program and not this config aspect?
    Jul 2008
    TURKIYE-KONYA
    OPEN YOUR PBP FOLDER AND FIND 12F683.INC
    YOU WILL SEE
    NOLIST
        ifdef PM_USED
            LIST
            include 'M12F683.INC'	; PM header
            device  pic12F683, intrc_osc_noclkout, wdt_on, mclr_on, protect_off
            XALL
            NOLIST
            LIST
            LIST p = 12F683, r = dec, w = -302
            INCLUDE "P12F683.INC"	; MPASM  Header
            __config _INTRC_OSC_NOCLKOUT & _WDT_ON & _MCLRE_ON &_CP_OFF
            NOLIST
            LIST
    CHANGE THE RED PART AFTER ELSE TO THIS ;
    NOLIST
        ifdef PM_USED
            LIST
            XALL
            NOLIST
            LIST
            NOLIST
            LIST
    AND YOU DONT NEED TO WRITE "@ DEVICE" STATEMENT AT THE BEGINNING OF YOUR CODE ANYMORE.
    Sep 2009
    South Wales (UK)
    Excellent!!! I was just reading another persons similar problem and was trying to track it down. Many thanks for that. It does indeed now compile and MPLAB IDE lets me upload the code to the PIC.
    Out of interest, is there any way that I can check if the thing has actually switched to the external oscillator [short of removing the oscillator!] by looking at the assembler file?
    Many thanks all for help with this - has been bugging me for hours!
    COOL!!!
    You are using MPLAB!!!!
    Tool bar - configure - configuration bits.
    That shows the current sttings.
    Sep 2009
    South Wales (UK)
    Haha, you make it sound soooooooooo easy :P
    'XT' Cheers
    I was hoping that this would help with my serial comm's issue but it hasn't lol. Maybe try another PIC, one with a serial interface built in perhaps?!
    I'll persist with this PIC for now and try to do some error-checking handshaking.
    I can say that I've definitely learned something today
    Best regards to all
    J.
    Now that the configs seem to be worked out, post your code and tell what is happening or not happening and we will see what can be done about it.
    In my opinion forget about using PM, always use MPASM. Later PM will nor work when you get into different things.
    Now I forgot to tell you when you set the fuses in code space you will have to comment out some lines in the chips *.inc file that is in the PBP directory.
    Or you can modify the *.inc file.
    My inc for this chip looks like this.
    ;*  12F683.INC                                                  *
    ;*  By        : Leonard Zerman, Jeff Schmoyer                   *
    ;*  Notice    : Copyright (c) 2005 microEngineering Labs, Inc.  *
    ;*              All Rights Reserved                             *
    ;*  Date      : 08/31/05                                        *
    ;*  Version   : 2.46a                                           *
    ;*  Notes     :                                                 *
            NOLIST
        ifdef PM_USED
            LIST
         ;   device  pic12F683, intrc_osc_noclkout, wdt_on, mclr_on, protect_off
            XALL
            NOLIST
            LIST
         ;   __config _INTRC_OSC_NOCLKOUT & _WDT_ON & _MCLRE_ON & _CP_OFF
            NOLIST
            LIST
  1. Interruptus Frustratus
    Last Post: - 17th April 2009, 21:36
  2. Using SPI with External Interrupts
    By shaiqbashir in forum mel PIC BASIC Pro
    Last Post: - 29th June 2008, 05:08
  3. Help with sound command in 2 programs
    Last Post: - 5th July 2007, 21:36
  4. error on compiling
    By parker in forum mel PIC BASIC Pro
    Last Post: - 16th June 2005, 15:31
  5. How to set external clock source in PBP
    By TurboLS in forum mel PIC BASIC Pro
    Last Post: - 19th February 2005, 16:56
