Multi Interrupt How To ?
Results 1 to 6 of 6
    capitano's Avatar
    capitano Guest
    Post Multi interrupt
    The PIC is 16F8777 at 20 Mhz
    I try to change :
    Disable
    interr:
    Enable
    to
    interr:
    Disable
    Enable
    but i have problem to ccp module to capture period of 1 ms the measure are instable but without interrupt the measure are correctly
    This program work fine
    ' Main Program Loop
    Loop:
    ' Sample Section
    TMR1L=0 ' Reset Timer
    TMR1H=0 ' Remember Timer is OFF
    capture=0 ' Reset Capture Flag
    CCP1CON = %00000100
    ' Enable the CCP1 capture, falling edge
    While Capture=0:Wend
    ' Junk 1st Result
    T1CON.0=1
    ' Enable Timer
    ' Wait for 2nd Result
    period.lowbyte = CCPR1L
    period.highbyte = CCPR1H
    ' Store the captured value in period variable
    T1CON.0=0 ' Timer is OFF
    CCP1CON=0 ' Capture is OFF
    Hserout[period.highbyte,period.lowbyte]
    Goto Loop
    This program don't work fine
    INTCON = %11100000
    PIE1=%00101111
    ON INTERRUPT GoTo interr
    mainloop:
    ' Main program
    GoTo mainloop
    ' Interrupt Header
    Disable
    interr:
    'Interrupt PWM
    IF PIR1.1=1 Then ' TMR2 to PR2 interrupt flag
    PIR1.1=0
    ' Interrupt routine
    'Interrupt Period
    If pir1.2=1 then
    pir1.2=0
    If state=0 then
    T1CON.0=1 ' Enable Timer
    pir1.2=0 ' Reset Capture Flag
    state =1
    CCP1CON = %00000101
    Period.lowbyte = CCPR1L
    Period.highbyte = CCPR1H
    CCP1CON = %00000101
    state=0
    'Interrupt TMR0
    If INTCON.2=1 then
    ' Interrupt routine
    INTCON.2=0
    'Interrupt Network
    IF PIR1.5=1 Then
    ' Interrupt routine
    Resume
    Enable
  1. Won't go back to SLEEP after 1st Interrupt
    Last Post: - 29th June 2009, 10:00
  2. Can't ID interrupt source with this IntHandler??
  3. Help with Analog Interrupt
    By brid0030 in forum mel PIC BASIC Pro
    Last Post: - 13th February 2008, 19:14
  4. NEWBIE: Some basic questions using interrupts
    By JackPollack in forum mel PIC BASIC Pro
    Last Post: - 8th March 2006, 03:59
