splitting output from a counter
Results 1 to 4 of 4
    Nov 2008
    Ok we finally got the code working. This picture explains it much better. The yellow trace is a 1.5Khz square wave. The purple and green traces are the resulting outputs.
    @	__CONFIG _INTOSCIO & _FCMEN_OFF & _IESO_OFF & _BOD_OFF & _BOD_OFF & _CP_OFF & _MCLRE_OFF & _PWRTE_ON & _WDT_OFF
    DEFINE OSC 8           ' Internal 8MHz
    CMCON0 = 7   			'Comparators off
    ADCON0 = %00000000		'ADC enabled and right justified
    ANSEL = %00000000		'GPIO.0 and GPIO.1 analog input
    INTCON = 0				'INTERRUPTS off
    OSCCON = %01110000		'8 Mhz
    TRISIO = %000100		'GPIO2 input
    GPIO = %00000100 		'All outputs = 0 on boot
    OPTION_REG = %00101000	'
    INCLUDE "Modedefs.bas"
    A	VAR	word
    A=0
    TMR0= 0
    input GPIO.2
    while TMR0 <= 5
    wend
    A = A+1
    TMR0= 0
    if A <> 5 then pulsout GPIO.5, 400
    if A=5 then onepulse
    'TMR0= 0  								 pause
    gosub main
    onepulse:
    TMR0= 0
    pulsout GPIO.4, 400
    A=0
    gosub main
  1. Conway's Game Of Life
    Last Post: - 28th May 2020, 07:14
  2. 20 Digit Virtual LED Counter
    Last Post: - 19th November 2007, 06:02
  3. Microcontroller with 2 way paging application problem
  4. Serious Serial Situation Setbacks...
  5. HSEROUT Newbie question/problem
    By Mark Scotford in forum mel PIC BASIC Pro
    Last Post: - 11th July 2006, 15:44
