splitting output from a counter
Results 1 to 4 of 4
    Nov 2008
    Default splitting output from a counter
    Hello all, I'm trying to figure out a way to have a 12F683 take a variable frequency square wave in and generate a pulse train out from two pins. The input would never go above 3Khz and the output would look like this:
    pin3-pin2-pin2-pin2-pin2-pin3-pin2-pin2-pin2-pin2-pin3
    One pulse from pin 3 and then four pulses from pin 2 all depending on the incoming frequency. The code so far doesn't seem to work very well.
    @	__CONFIG _INTOSCIO & _FCMEN_OFF & _IESO_OFF & _BOD_OFF & _BOD_OFF & _CP_OFF & _MCLRE_ON & _MCLRE_OFF & _PWRTE_ON & _WDT_OFF
    DEFINE OSC 8           ' Internal 8MHz
    'DEFINE ADC_BITS 8      ' 8-bit resolution
    'DEFINE ADC_CLOCK 2     ' Set clock source to Frc/32
    'DEFINE ADC_SAMPLEUS 50 ' Sample time in uS before A/D conversion is started
    CMCON0 = 7   			'Comparators off
    ADCON0 = %00000000
    ANSEL = %00000000
    INTCON = 0			'INTERRUPTS off
    OSCCON = %01110000		'8 Mhz
    TRISIO = %000100
    GPIO = %00000100
    OPTION_REG = %00101000
    A	VAR	byte
    TMR0= 0      ' clear count
    low GPIO.4
    low GPIO.5
    input GPIO.2
    A=0
    while TMR0 <= 5
    wend
    A= A+1
    if A = 4 then largepulse
    pulsout GPIO.5, 100		'500 uS short pulses pin 2
    gosub main
    largepulse:
    pulsout GPIO.4, 100		'500 uS big pulse pin 3
    A=0
    Am I way off here or on the right track?
    Nov 2007
    West Covina, CA
    Just a few things to start off with:
    Choose one
    ADCON0 = %00000000
    ANSEL = %00000000
    TRISIO = %000100
    GPIO = %00000100
    A	VAR	byte
    low GPIO.4
    low GPIO.5
    input GPIO.2
    A=0
    main: 'You'll probably want to "see" what's happening on GPIO.2 once you get this part done I reckon
    while TMR0 <= 5
    wend
    A= A+1
    if A = 4 then GOSUB largepulse   ' lets the four pulses go first then jumps to "large pulse"
    GOTO main   ' GOTO here instead
    largepulse:
    A=0
    There's probably more but that's what I see for now.
    Louie
    Hi astouffer,
    execute a subroutine . . .
    counter var byte
    . . . . . your code . . . .
    gosub goesout
    . . . . more code . . . .
    goesout:
    Pulseout 10, pin3
    for counter = 0 to 3
    pulseout 10, pin2
    next counter
    Please forgive if the pulseout is wrong as I am not home and have no manual here . . .
    But you get the Idea.
    Nov 2008
    Ok we finally got the code working. This picture explains it much better. The yellow trace is a 1.5Khz square wave. The purple and green traces are the resulting outputs.
    @	__CONFIG _INTOSCIO & _FCMEN_OFF & _IESO_OFF & _BOD_OFF & _BOD_OFF & _CP_OFF & _MCLRE_OFF & _PWRTE_ON & _WDT_OFF
    ADCON0 = %00000000		'ADC enabled and right justified
    ANSEL = %00000000		'GPIO.0 and GPIO.1 analog input
    TRISIO = %000100		'GPIO2 input
    GPIO = %00000100 		'All outputs = 0 on boot
    OPTION_REG = %00101000	'
    INCLUDE "Modedefs.bas"
    A	VAR	word
    A=0
    TMR0= 0
    input GPIO.2
    while TMR0 <= 5
    wend
    A = A+1
    TMR0= 0
    if A <> 5 then pulsout GPIO.5, 400
    if A=5 then onepulse
    'TMR0= 0  								 pause
    gosub main
    onepulse:
    TMR0= 0
    pulsout GPIO.4, 400
    A=0
    gosub main
  1. Conway's Game Of Life
    Last Post: - 28th May 2020, 06:14
  2. 20 Digit Virtual LED Counter
    Last Post: - 19th November 2007, 05:02
  3. Microcontroller with 2 way paging application problem
  4. Serious Serial Situation Setbacks...
    Last Post: - 7th February 2007, 03:46
  5. HSEROUT Newbie question/problem
    By Mark Scotford in forum mel PIC BASIC Pro
    Last Post: - 11th July 2006, 14:44
