Problem implement "Henrik" incPID
Results 1 to 5 of 5
    May 2007
    Republic Serbia
    Default Problem implement "Henrik" incPID
    Hello to all ..
    I have PMDC with quadrature encoder and reading encoder from 0-2000 work OK.Command for my logic for motor with Mosfets work on next way:
    I use PWM with Duty from 0-1024 (10bit) at 19.2Khz.
    Motor stay at place when Duty is 512.
    0<---LEFT----512----RIGHT--->1024
    fast<-----Slow---stay----slow---->fast
    That is command and speed via one PWM signal ;-)
    All that things work good.
    But I have problem to implement "Henrik" PID rutine for position 0-2000.
    If I set setpoint to 100 it work after that not....
    calculation for mirror of duty is (512 - pid_out) + 512
    Here is test code:
    '                 Definicije PIC-a  18F4431                     *
        DEFINE OSC 20
        include "incPID.pbp"
    '                         RS 232 HSEROUT 19200 kbps             *
        DEFINE HSER_RCSTA 90h                      ' Enable serial port & continuous receive
        DEFINE HSER_TXSTA 24h                      ' Enable transmit, BRGH = 1
        DEFINE HSER_SPBRG 64                       ' 19200 Baud @ 20MHz, 0.16%
        DEFINE HSER_CLROERR 1                      ' Clear overflow automatically
    '                          Definicije Portova                   *
        ADCON0=0                                   'Turn of ADC
        ANSEL0=0                                   'Turn of ADC
        PortA = 0                                  'Make Port A inputs Digital
        PortB = 0                                  'Make Port B inputs Digital
        PortC = 0                                  'Make Port C inputs Digital
        TRISB = %00000000                          'Port B all  outputs ON
    '                          Definicije QEI encodera              *
        QEICON = %10011000
        DFLTCON = %00111000
        MAXCNTL = %11001111
        MAXCNTH = %00000111
        PosLow VAR BYTE                             'Storage for the low byte of encoder count
        PosHigh VAR BYTE                            'Storage for the high byte of encoder count
        PosTemp VAR BYTE                            'Temporary storage for low byte of encder count
        Position VAR WORD                           'Actual encoder position, 16bit word.
        POSCNTL = 0                                 ' clear lowbyte of counter for start
        POSCNTH = 0                                 ' clear highbyte of counter for start
    '                          Definicije PID filtera               *
        ADValue VAR byte                           '<---This is your variable.
        Setpoint VAR WORD                          '<---This is your variable.
        Direction var byte                          '<---Direction bit to motor driver
        pid_Kp = $0700                             'Set Kp to 7.0
        pid_Ki = $0080                             'Set Ki to 0.5
        pid_Kd = $0225                             'Set Kd to 2.14
        pid_Ti = 8                                 'Update I-term every 8th call to PID
        pid_I_Clamp = 100                         'Clamp I-term to max ±100
        pid_Out_Clamp = 512                       'Clamp the final output to ±511
        Setpoint = 100
    '                          Osnovna petlja PID-a                 *
    Start:
       Gosub Getposition
       advalue = position
       pid_Error = Setpoint - ADValue               'Calculate the error
       Gosub PID                                    'Result returned in pid_Drive
       Direction = pid_Out.15                       'Set direction pin accordning to sign
       pid_Out = ABS pid_Out                        'Convert from two's comp. to absolute
       if direction  = 0 then hpwm 1,pid_out,19200                     ' run motor left
       if direction  = 1 then  hpwm 1,(512 - pid_out) + 512,19200 ' run motor right
       pause 10                                     '.......little pause for debug.
       hserout [dec pid_out]
       Goto Start                                   '.......again.
    '                          Petlja QEI-a                         *
    GetPosition:
        PosHigh = POSCNTH                           'Get high byte of counter
        PosLow = POSCNTL                            'Get low byte of counter
        PosTemp = POSCNTL                           'Get low byte again
        If PosLow - PosTemp = 0 then Goto Done      'Compare, if equal we're done.
        PosHigh = POSCNTH                           'If not, get values again.
        PosLow = POSCNTL
    Done:
        Position = POSHIGH * 256 + PosLow           'Put high and lowbyte together.
    If any suggest pls.
    The Best regards Robert.
    Is that the whole code?
    Maybe I have been looking at a green screen to long but I do not see where "setpoint" is being used.
    Bombay, India
    ADValue is byte sized, so it is limited to 255. Is that why it is not working?
    phoenix_1, The code as written is assuming setpoint is set which after a reset is probably defaulted to 65535....
    May 2007
    Republic Serbia
    I was post my debug code in incPID trade from Henrik..see if you have time pls.
  1. USART Problem , but don't know where, in pc? or in PIC?
  2. Hardware problem or what ?
    By Steve S. in forum mel PIC BASIC Pro
    Last Post: - 4th March 2007, 22:39
  3. PicBasic Pro Math Problem??
    By Glen65 in forum mel PIC BASIC Pro
    Last Post: - 5th March 2006, 05:36
  4. 1 slave 1 master 1 MAX232 1 problem ?
    Last Post: - 31st July 2005, 23:59
  5. weird 12F629/675 problem
    By peterdeco1 in forum mel PIC BASIC Pro
    Last Post: - 7th October 2004, 02:08
