brown out resets
Results 1 to 23 of 23
    Aug 2009
    ok ive made my code, probably got some errors in, however thats not the problem. ive been thinking about this whole trouble with if the voltage is idling on a point lower than my low voltage detection level but not low enough that it causes a reset... problem is.. if it gets too that point my program starts looping because the interupt keeps getting set off by the low voltage.
    i was thinking since when the wind turbine actually gets slow enough that the voltage is about 2-3 volts, its not actually giving out any power (if it does then its completely negligible). so when i get to a low point can i just turn off the pic? and get it too restart when the power gets higher?
    You might be able to use an external comparator to watch the voltage and kill the PIC that way....
    What about a small rechargable battery pack to run the PIC for a few hours then the PIC is always on.
    Aug 2009
    im gonna look into the battery idea actually, but flaws with it could be that over 20 years a rechargeable battery will have effectively "lost its ability to recharge" and also there will be points where the wind is dead for longer than the battery can keep the pic and lcd running...
    are there any commands to just turn off the pic and then get it back going when the voltage is high enough? cos surely if the pic is turned off... how can it be turned back on again? since the software is obvioulsy not running because the pic is off :S
    Aug 2009
    actually does the power on reset turn the pic back on after i have turned it off? if i put the mclr pin to Vdd, it will detect a rise in voltage? and cause a reset?
    if i turned the pic off at a certain voltage... and then when the pic detects a rise in voltage the power on reset occurs and turns my pic back on and restarts the program?
    Quote Originally Posted by robertpeach View Post
    Pros and cons no matter what. I have one of the "smart thermostats" at the house. It runs on two AA batteries that need changed once a year or so. Might have to be a bit of upkeep for the end user???? I know, not good.
    There is the sleep command but that just puts the PIC in low power mode.
    I have a feeling that the best way to go will be an external comparator working a latching relay or FET on the 12 volt line. Rig it so when the voltage drops below X the relay stays off untill the voltage comes back up to Z. Give a little range between the two points.
    Then the interrupt thing should work. If the PIC shuts down only from lack of power it will restart.
    Just thinking.... Or is it babbling
    Aug 2009
    no ive been thinking and the ways that you describe are the only two ways i can think of doing it... the battery thing would work nicely i just dont think a customer would be too happy having to change batteries much...
    im gonna try out ur second example with the comparator! thanks for your help once again mack! ill let u know how it goes
    Aug 2009
    update:
    well basically dave i looked into the whole idea... and basically it just seemed all a bit much for one thing. ive decided on the simplest option, even if it is a bit time consuming and not as efficient for the pic. im just gonna save the data to eeprom every 0.25 kwh instead of only saving when pic powers down... this will require a bit more pic power and wont be as accurate since it could be 0.24kwh through when the pic dies... and that 0.24 kwh is not actually added on... this could happen quite alot if the wind is low and the turbine keeps starting and stopping...(although it wont matter that much since the energy out at those stages is pretty negligible anyway) but will be cheaper and easier probably! less things to go wrong in my case
    One more thought....
    To keep from missing that last bit of good data you could have the code do a last write when the power, speed or what ever drops to a certain point. Anything below that point and you do not write data. Once the machine is running above a certain point it goes back to writing every 0.25kwh. That way the starts and stops will not bother.
  1. 16f877a porta.5 resets chip
    By lecoind in forum mel PIC BASIC Pro
    Last Post: - 1st October 2009, 18:29
  2. Device Resets / erratic operation - 16F88
    By turbokinetic in forum mel PIC BASIC Pro
    Last Post: - 11th April 2009, 03:08
  3. servo motor resets 16f877a
    By burak450 in forum mel PIC BASIC Pro
    Last Post: - 19th October 2008, 22:25
  4. PIC resets every now and then
    By passion1 in forum mel PIC BASIC Pro
    Last Post: - 12th June 2007, 21:41
  5. Freqout resets port pins?
    By MikeLewis in forum mel PIC BASIC Pro
    Last Post: - 16th July 2004, 04:29
