Synchronous USART problems... HELP!!!
Results 1 to 8 of 8
    moni's Avatar
    moni Guest
    Default Synchronous USART problems... HELP!!!
    Hi Folks,
    I have looked and nobody seems to ever approached the Synchronous high speed issue, so here's a little challange:
    I am trying to transmit a string SYNCHRONOUSLY using HSEROUT with no luck.
    after reading MicroChip's docs, it seems that the SPEN,SYNC and CSRC bits must be set, so I tried:
    DEFINE HSER_SPBRG 59 ' BAUD RATE = 83.333 KBAUD
    DEFINE HSER_RCSTA 20h '
    DEFINE HSER_TXSTA 90h ' sets CSRC and SYNC bits
    DEFINE HSER_CLROERR 1 ' just in case of overflow
    and then some hserout commands like this one:
    HSerout [$11,$12,$13,$23,$34,$43,$81,$13,$3A]
    right after that I had a LCDout command for debugging purposes.
    THE PROGRAM NEVER GOT TO THE LCDOUT PART!!! nothing happend. no serial output, no clock, nothing!
    so I started REM'ing out the defines one by one. the problem was the DEFINE HSER_TXSTA 90h. I have changed it to 20h just to be sure,
    and of course it worked, but Asynchronously.
    Am I doing something wrong or HSERout is limited to Async???
    Please show me the light!
    M.M.
    New York
    moni's Avatar
    moni Guest
    Default Forget to mention...
    PS I am using a 20mhz xtal, the pic is a 16F628 on a LAB-X3 board, and yes, the baud rate is 83.3333 kbaud, which is a can-bus sub-standard.
    tnx!
    M.M.
    Oct 2003
    Cyprus
    First, you must include a DEFINE OSC 20 .
    Second, the line HSerout [$11,$12,$13,$23,$34,$43,$81,$13,$3A]
    I thing does not work like this, put
    HSerout ["11121323344381133A"] instead.
    Kypros
    moni's Avatar
    moni Guest
    Kypros,
    Tnx for the reply, but I do have DEFINE OSC 20.
    and there is no problem using
    it's a standard hex serial out format (look at the PBP manual)
    electronicsuk's Avatar
    electronicsuk Guest
    Possibly you're causing an overflow error? Although I don't see why that would halt the program.
    Matthew
    johnramsbottom's Avatar
    johnramsbottom Guest
    Moni, I'm not sure which PIC you're using. I'm used to using the USART on the 16F7XX series but I don't think the associated registers differ much. Are you setting TXEN? This is bit 5 in TXSTA register. You could just put a hex value of B0h into TXSTA (to set CSRC and SYNC also). Also your value of 20h for TXREG seems a bit odd. Surely you need 80h in RCSTA.
    Hope you get somewhere.
    John R
    Sorry, I meant to say RXSTA and not TXREG, but you probably realised. I'm confusing the issue!
    John R
    Sorry I 'm still wrong. I meant RCSTA and not TXREG in my original reply.
  1. My USART problems..
    By Glenn in forum mel PIC BASIC Pro
    Last Post: - 31st July 2009, 01:00
  2. problem with USART
    By leemin in forum Serial
    Last Post: - 11th December 2006, 17:56
  3. USART TXREG Problems
    By BigH in forum Serial
    Last Post: - 11th January 2006, 00:30
  4. USART problems
    By egberttheone in forum mel PIC BASIC Pro
    Last Post: - 6th March 2005, 21:45
  5. Replies: 5
    Last Post: - 1st December 2004, 12:49
