Sony LanC Program
Results 1 to 25 of 25
    Aug 2009
    Paso Robles California
    Default sony lanc
    Grounded
    I don't know whats wrong! I do indeed have it running right now, It has been running all day taking pictures every 15 minutes for 5 seconds at a time. PBP does indeed work and the timing is really not that tight. I did notice your using xt setting I have always used HS mode, have not looked over your program much yet. I see no reason that 4 mhz would not work.
    Aug 2009
    Default Sony LanC
    grounded,
    here try this I made some changes in your program headers see if this works better for you.
    	@ DEVICE PIC16F676, HS_OSC, WDT_ON, PWRT_ON, PROTECT_OFF
    	TRISC = %00010000
       command_bit var   bit
       syncbit     var   byte
       syncbyte    var   word
       counter     var   byte
       value       var   byte
       Bits        var   byte
       Time        var   byte
    	PAUSE 2000
    	Goto start
          Sync_byte:
       syncbyte = 0
       while syncbyte < 700
       pulsin portc.4, 1, syncbyte
       wend
          Sync_bit:
       syncbit = 0
       while syncbit < 9
       pulsin portc.4, 0, syncbit
       wend
          Command_byte:
          gosub sync_byte
       pauseus 80
       input portc.5               'first byte to send (LSB 1ST)Hex 18 %0001,1000
       pauseus 312    '000
       low portc.5
       pauseus 208    '11
       input portc.5
       pauseus 312    '000
       input portc.5                       'Stop bits set high
             Start:
       counter = 0
       gosub Power_off
       pause 10000
       'gosub DelayTime
       counter = 0
       gosub Wakeup
       'gosub Power_on
       pause 3000
       counter = 0
       gosub Record_on
       pause 10000
       counter = 0
       gosub Record_on
       goto Start
          Power_off:
          gosub Command_byte
          gosub sync_bit
       input portc.5                       'Power off command #5E (LSB 1ST) %0101,1110
       pauseus 104    '0
       low portc.5
       pauseus 416    '1111
       input portc.5
       pauseus 104    '0
       low portc.5
       pauseus 104    '1
       input portc.5
       pauseus 104    '0
          counter = counter + 1
          if counter = 3 then Return
          goto Power_off
          Power_on:
          gosub Command_byte
          gosub Sync_bit
       input portc.5
       pauseus 208     '00         'Power on Command 5C (LSB 1ST) %0101,1100
       low portc.5
       pauseus 312     '111
       input portc.5
       pauseus 104     '0
       low portc.5
       pauseus 104     '1
       input portc.5
       pauseus 208     '00 ????? maybe 104
          if counter = 5 then Return
          goto Power_on
          Record_on:
          gosub Command_byte
          gosub Sync_bit
       low portc.5                         'Start Recording
       pauseus 208   '11                      'Record On 33 (LSB 1ST) %0011,0011
       input portc.5
       pauseus 208    '00
       low portc.5
       pauseus 208    '11
       input portc.5
       pauseus 208    '00
          goto Record_on
             DelayTime:
       For Time = 0 to 60
       pause 60000
             Next Time
             Wakeup:
       low portc.5       'This wakes camera up for short period to accept commands
       input portc.5
    Aug 2005
    down south
    Thumbs up up and running
    Larry 676 does not have hs_osc so it would not compile thanks for trying
    BUT:
    I'm up and running (cross fingers)
    remember I said something about adjusting to midpoint of the bit
    well I did 'Command_byte:you had dropped it from104 to 80 to adjust timing
    I dropped to 60 (about half) and bingo it's running (started@ 70 and it ran)
    I think 80 is right on the edge that's why sometime it work and then the next
    it did'n
    and this is with my standard Lanc control board using
    1 pin to read / write no pull up or down 60 ohm resistor in Lanc line
    this basic program just start recording 10 sec. movie then stop wait
    5 sec. and start over. If it will run one command it should run ALL
    it's been running for about 2 hr. with out missing abeat
    Now the bad news the next few days are full full full . not sure it I will have time to eat much less to play I mean work on this
    I would be interested to know how it looks on the scope
    grounded
    '*  Name    : pbplanc_T_1833.BAS
    '*  Author  : GROUNDED
    '*  Notice  : Copyright (c) 2009
    '*          : All Rights Reserved
    '*  Date    : 9/25/2009
    '*  Version : 1.0
    '*  Notes   : testing pbp lanc  basic just record and stop
       pic16F676
    @ __config _XT_OSC & _WDT_ON & _MCLRE_OFF & _CP_OFF
    PAUSE 5000
    CMCON = 7
    VRCON = 0
    TRISA = %00001000
    TRISC = %00000000
    ANSEL = %00000000
    OPTION_REG=%01000000
    WPUA = %00000000
    HIGH PORTC.0  :PAUSE 3000 :LOW  PORTC.0     'POWER UP LED
     PAUSE 1000
     command_bit var bit
     syncbit var byte
     syncbyte var word
     counter var byte
     value var byte
     Bits var byte
    Goto start
     Sync_byte:
     syncbyte = 0
     pulsin PORTC.4, 1, syncbyte
     wend
     Sync_bit:
     syncbit = 0
     while syncbit < 9
     pulsin PORTC.4, 0, syncbit
     wend
     Command_byte:     '00011000   SEND 18
     gosub sync_byte
     pauseus 60   'CHANGED FROM 80 TO 60 (LITTLE OVER HALF OF 104) TIMING ADJUST
     input PORTC.4
     pauseus 312  '000
     low PORTC.4
     pauseus 208  '11
     input PORTC.4
     pauseus 312  '000
      input PORTC.4 'Stop bits set high
     START:
    Record_on:           '11001100   SEND 33
     gosub Command_byte
     gosub Sync_bit
     low PORTC.4
     pauseus 208   '11
     input PORTC.4
     pauseus 208   '00
     low PORTC.4
     pauseus 208   '11
     input PORTC.4
     pauseus 208   '00
     counter = counter +1
     if counter = 4 then  GOTO  MT
     goto Record_on
     MT:
      COUNTER =0
    PAUSE 10000    '10 SEC. MOVIE
      Record_off:           '11001100    SEND 33
     gosub Command_byte
     gosub Sync_bit
     low PORTC.4
     pauseus 208   '11
     input PORTC.4
     pauseus 208   '00
     low PORTC.4
     pauseus 208   '11
     input PORTC.4
     pauseus 208   '00
     if counter =4 then GOTO OVER
     goto Record_OFF
     OVER:
     PAUSE 5000
    GOTO START
    " be nice it's people like me that make people like you look smart"
    yes I read the datasheet, of the 300 pages I understood 10
    Aug 2009
    Default Sony Lanc
    Grounded
    I tested using 60mS and yes it worked for me also, I also tested not using the power on command and issuing a Record command after a pull-down wakeup it also worked.
    looks as if I was on the edge @ 80 if I can find a 4mhz board around I will test the 80 using it, so if 60 to 80 works maybe lower then the timing is not so critical I guess!
    Thanks for your help in working this out now MANY can enjoy
    You would think I would know how to spell TESLA by now
    Aug 2005
    down south
    Default full blown camera code
    I dropped the PBP LanC read/write in to some of my generic PBP camera code
    because I was able to read/ write with 1 pin like I do with the assembly code
    I could just drop the PBP version in the 16f676 and the camera is up and running
    thanks
    '*  Name    : pbp_sony_n.BAS                                    *
    '*  Author  : R Slaton  AKA Grounded /Ratsnest                  *
    '*  Notice  : Copyright (c) 2009 peek-a-boo wild life systems   *
    '*  Date    : 9/23/2009                                         *
    '*  Notes   : SONY LanC NIGHTTIME ONLY WITH IR LED ARRAY        *
    '*          :DIP 1 ON 60SEC. MOVIE /30 SEC DEFAULT              *
    '*          :DIP 2 ON 60 AFTER MOVIE DELAY /30 DEFAULT
    '*          :PIR TRIPS HIGH/15SEC.TEST MOVIE @ CONTROLLER BOOTUP
    '*     :THANKS TO l_gaminde ON THE BIT BANGING READ WRITE PART
       pic16F676
    'DEFINE OSC 4               'EXTERNAL CLOCK SPEED 4MH.
    DEFINE ADC_BITS 10          'ADC 10 BIT #
    DEFINE ADC_CLOCK 3          'ADC SAMPLE CLOCK
    DEFINE ADC_SAMPLEUS 50	    'SAMPLE EVERY 50 US.
    Pause 5000                  'DELAY TO LET STABILIZE AFTER POWER UP & MODE
    CMCON = 7                   'COMPARATOR OFF
    VRCON = 0                   'VOLTAGE REF. DISABLE
    TRISA = %00001101           'MAKE A.2 & A.3 INPUTS
    TRISC = %00000110		    'MAKE .C.0,C.1 PORTC INPUTS
    ANSEL = %00000001           'PORTA.0 A/D IN,RST DIGITAL
    ADCON0.7 = 1                'RIGHT JUSTIFY FOR 10 BIT
    OPTION_REG=%01000000        'RAISING EDGE/WEAK PULL UP
    WPUA = %00000000            'NO WEAK PULLUPS
    SYMBOL ADC  =PORTA.0         'ADCIN
    SYMBOL LDR  =PORTA.1         'PHOTO CELL POWER
    SYMBOL PIR  =PORTA.2         'PIR TRIPS HIGH
    SYMBOL MODE =PORTA.3         'MODE BUTTON
    'SYMBOL XT   =PORTA.4        'XT_OSC
    'SYMBOL XT  =PORTA.5         'XT_OSC
    SYMBOL LED =PORTC.0          'LED & DIP SWITCH
    SYMBOL DIPB =PORTC.1         'DIP SWITCH 2
    SYMBOL DIPA  =PORTC.2        'DIP SWITCH 1
    SYMBOL RL   =PORTC.3         'REMOTE LIGHT
    SYMBOL LANC =PORTC.4         'READ /WRITE LANC
    SYMBOL NA =PORTC.5           'FOR SERVO OPTION
    ADC=0:LDR=0:PIR=0:MODE=0:LED=0:DIPA=0:DIPB=0:LED=0:RL=0:LANC=0:NA=0
      LED=1 :PAUSE 5000 :LED=0
     GOTO TESTMOVIE
    '****************************SET UP VARIBLES***************************
    DT VAR BYTE  :DT =30          'AFTER MOVIE DELAY VAR. /30 SEC. DEFAULT
    DAY VAR BYTE :DAY=0           'DIP SWITCH 1 VAR FOR DAY ONLY OR DAY/NIGHT
    ML VAR BYTE :ML=0             'DIP SWITCH 2 VAR FOR VARIBLE MOVIE LENGTH
    RCL VAR BYTE :RCL=0           'RECORD LED VAR
    NIGHT VAR WORD:NIGHT=0        'LDR/ADCIN VAR FOR LIGHT SENSOR
    command_bit var   bit
    syncbit     var   byte
    syncbyte    var   word
    counter     var   byte
    value       var   byte
    Bits        var   byte
    Time        var   byte
    '***********************DAY/ NIGHT PHOTO CELL CAL MODE*******************
    IF MODE=0 Then GoTo  CAL  'IF MODE BUTTON PUSHED THEN GOTO LRD CAL MODE
    GoTo testmovie                  'SKIP CAL MODE  GO CHECK DIP SWITCHES
    CAL:
    LDR=1:Pause 250           'TURN LDR/ADCIN POWER ON
    LED=1:Pause 250:LED=0:Pause 250
    LED=1:Pause 250:LED=0:Pause 1000  ' FLASH YOUR IN CAL MODE
    TEST:
    NIGHT=0
    LED=0
    ADCIN 0,NIGHT          'CHECK AN# READ AN0 & STORE IN NIGHT VAR
     IF NIGHT=>550  Then LED=1   'IF LED IS ON THEN NIGHT MOVIE
     Pause 250                   ' IF OFF DAYTIME
     IF MODE =0 Then GoTo testmovie    'LEAVE CAL MODE
     GoTo TEST                   'LOOP AND CHECK FOR LIGHT AGAIN
    '*********************************SET UP SUBS****************
         Sync_byte:        'Sync_byte looks for the inter_frame gap
       syncbyte = 0
       wend
          Sync_bit:    'Sync_Bit looks for the start_bit of each frame
       syncbit = 0
       while syncbit < 9
       wend
          Command_byte:    'tell camera that a command is to follow normal commands
          gosub sync_byte
       pauseus 55           'pause for camera's start bit to finish 55= MID OF BIT
       input portc.4          'first byte to send (LSB 1ST)Hex 18 %0001,1000
       pauseus 312    '000
       low portc.4
       pauseus 208    '11
       input portc.4
       pauseus 312    '000
       input portc.4                       'Stop bits set high
         Record_SS:
          gosub Command_byte
          gosub Sync_bit
       low portc.4               'USED TO STOP AND Start Recording
       pauseus 208   '11          ' 33 (LSB 1ST) %0011,0011
       input portc.4
       pauseus 208    '00
       low portc.4
       pauseus 208    '11
       input portc.4
       pauseus 208    '00
          goto Record_SS
        Power_off:
          gosub Command_byte
          gosub sync_bit
       input portc.4             'Power off command #5E (LSB 1ST) %0101,1110
       pauseus 104    '0
       low portc.4
       pauseus 416    '1111
       input portc.4
       pauseus 104    '0
       low portc.4
       pauseus 104    '1
       input portc.4
       pauseus 104    '0
          goto Power_off
    '*********************************TESTMOVIE*******
    TESTMOVIE:
    COUNTER=0
    GOSUB RECORD_SS
    PAUSE 15000          '15 SEC. TEST MOVIE
    COUNTER=0
    GOSUB RECORD_SS
    PAUSE 3000
    COUNTER=0
    GOSUB Power_off
    '*********************************DIP CHECK****************
    CKD:
    night=0                     'CLEAR NIGHT VAR
    led=0                       'MAKE SURE LED IS OFF
    Pause 20
    LED=1 :Pause 250          'TURN DIP SWITCH POWER ON
    IF DIPA=0 Then ML=30
    IF DIPA=1 Then ML=60
    '***********************SET DELAY**************************
    IF DIPB=0 Then dt=30
    IF DIPB=1 Then dt=60
    Pause 300
    LED=0                      'TURN DIP SWITCH POWER OFF
    '****************************** PIR WARM UP & WALKTEST *************
    Sleep 50                        '50 SEC. PIR WARM UP
    LED=1:Pause 350:LED=0:Pause 500   'FLASH LED FOR START OF WALKTEST
    LED=1:Pause 350:LED=0:pause 500
    A VAR WORD
    For A= 0 TO 30000         '20 SEC. WALKTEST TIME RESETS WITH pir TRIP
    Pause 1
    IF PIR=1 Then               'IF PIR TRIPS THEN TURN ON LED
    LED=1
    Pause 1000
    LED=0
    Pause 500
    A=0
    EndIF
    Next A
    LED=1 :Pause 500 :LED=0 :Pause 300    'FLASH LED END OF WALKTEST
    SLEEP 20 :led=1 :Pause 500 : led=0   '20 SEC TO GET OUT OF THE WAY
    '************************ GOTO SLEEP & WAIT FIR INTERUPT **********
    MAIN:
    NIGHT =0                     'CLEAR NIGHT VAR TO 0
    ON INTERRUPT GoTo MOVIE      'ON PIR TRIP WAKE UP
    INTCON=$90                   'ENABLE .2 INTERUPT
    Sleep 900                   '15 MIN SLEEP
    GoTo MAIN                    'GO BACK TO SLEEP AND WAIT ON INTERUPT
    Disable
    '*************************************MAKE MOVIE ***************************
     MOVIE:
     INTCON=0                       'DISABLE ALL INTERUPTS
     pause 200
      IF PIR =0 then  sleep 60 :goto delay 'DID THE PIR CAUSE THE INTERUPPT
      LDR=1                         'POWER UP LIGHT SENSOR
     Pause 20
     ADCIN 0,NIGHT                 'READ AN1 & STORE IN NIGHT VAR
      PAUSE 250
     IF NIGHT=<550 Then  SLEEP 120 :GOTO DELAY   ' IT'S DAY
     Pause 25
     LDR=0
     Wakeup:             ' WAKE CAM UP FROM POWER SAVING SLEEP MODE
       low portc.4     '
       input portc.4
    pause 3000                  'CAM BOOT UP TIME
    RL=1                        'TURN IR LED ARRAY ON
    counter=0
    gosub record_ss
     SLEEP ML                   'MOVIE LENGHT SET WITH DIP1 30/60
     counter=0
    gosub record_ss
    pause 5000                     'GOTO STANDBY
    counter=0
    gosub power_off                'PUT CAM TO SLEEP
    '******************************BETWEEN MOVIE DELAY *******************
    DELAY:
    LDR=0                           'MAKE SURE LDR/ADCIN POWER OFF
    RL=0                            'MAKE SURE REMOTE LIGHT IS OFF
    Sleep DT                        'DELAY SET WITH DIP2 30/60
        INTCON.1=0                 'RESET A.2 INTERUPT FLAG
        Disable
        GoTo MAIN              'GO BACK TO SLEEP AND WAIT FOR NEXT INTERUPT
    Enable
    Jul 2007
    this looks very cool guys!
    I hope I can test drive some of those routines soon.(used the ELM lanc chips in the past).
    I see that it write, but does it read LanC too?
    cheeers!
    Aug 2009
    Default sony lanc
    Flipper
    I have read LanC using a basic stamp and 9600 serin command so it could be implemented
    Larry
  1. Presetting Configuration Fuses (PIC Defines) into your Program
    Last Post: - 15th December 2013, 09:54
  2. Sony LanC Program
    By l_gaminde in forum Code Examples
    Last Post: - 25th September 2009, 18:51
  3. Replies: 1
    Last Post: - 23rd May 2009, 09:22
  5. PIC16F684 Program question
    By Nicholas in forum mel PIC BASIC Pro
    Last Post: - 28th December 2006, 14:30
