Sony LanC Program
Results 1 to 25 of 25
    Aug 2009
    Paso Robles California
    Thumbs up Sony LanC Program
    I have a starter program for Sony Lanc posted, with docs on Lanc using PBP ( the top two programs ) if anyone is intrested. this is done in bit banging and can be adapted to loops with some timing changes. all you need is a camera (video / Still ) one resistor and a pic chip.
    http://gaminde.net/SCS/
    Aug 2005
    down south
    Smile lanc
    very interested in this
    pm sent
    " be nice it's people like me that make people like you look smart"
    yes I read the datasheet, of the 300 pages I understood 10
    Aug 2009
    Default Sony lanc
    Try it out and let me know if you need help
    Aug 2009
    Default Reply
    If anyone tries this program please report your results and your
    camera's make/model. Have improvements report this also.
    Thanks Larry
    Aug 2005
    down south
    I have spent a few hours on this and the only way that I can even get it to work sometimes is: read and write with the same pin
    This is the way my Lanc controllers that I build work programmed in assembly.
    or the one I built using the elm interface chip.
    using your starter 33 is the only hex that will record or stop
    on mine I can use 27 or 33 record and 29 or 33 stop not sure what that's all about.
    right now IF it does start recording some times it will flicker between rec and standby. I will try to work on it some more and post were I'm @
    I have 5 different Sony corders I use one a mini dv and they are all interchangeble on my board
    thanks for working and sharing this and I hope what I have posted helps
    Aug 2009
    Default sony
    Ok sounds like you changed the program some to test different hex commands?
    You need the two different pins portb1 and and portb2 one looks for interframe gaps and startbits the other sends commands did you use the pulldown resistor on Portb1 and did you use two resistors one for each pin to the lanc line and of course ground I did it this way for testing so I could put the scope on either lead and check for pulse voltage. I found sometimes I needed the pulldown resistor to get clean pulses that would go 0 to 3vdc not 1.3 to 3vdc. Thanks for testing this, sometimes no matter how much you work on something, when someone tries it, it may or may not work and this is what I wanted to see.
    Now try the program as written turn the camera on first then turn the pic on the camera will shutoff wait 10 seconds turn on wait 10 seconds record wait 20 seconds stop record wait 10 seconds and turn off and go through all this again Im using a DCR-HC20 sony camera. I listed the commands that worked with my camera. Let me know what happens.
    Larry
    Aug 2009
    Default sony
    I have my camera on the desk Im using a BS2 to read the data stream comming from the camera and It works using serin 9600 and reversing the hex
    ' {$STAMP BS2}
    ' {$PBASIC 2.5}
    value VAR Byte(8)
    syncbyte VAR Word
    a VAR Byte
    a = %11111111
    start:
    Sync_byte:
    syncbyte = 0
    DO WHILE syncbyte < 3200
    PULSIN 1, 1, syncbyte
    LOOP
    SERIN 1,84,[value(0),value(1),value(2),value(3),value(4),value (5),value(6),value(7)]
    DEBUG HEX value(0)^a,TAB,HEX value(1)^a,HEX value(2)^a,HEX value(3)^a,HEX value(4)^a,HEX value(5)^a,HEX value(6)^a,TAB,HEX value(7)^a,CR
    'PAUSE 500
    GOTO sync_byte
    'GOTO start
    Aug 2005
    down south
    Sorry no luck
    I even tried it with my hc42
    the only thing different is I'm using a 16f676 XT_OSC @ 4
    were you @ 10
    right now I'm trying to keep all my camera in the woods. I ran and got a couple to help you test.
    I maybe out of pocket next few days with will try to do more testing later
  1. Presetting Configuration Fuses (PIC Defines) into your Program
    Last Post: - 15th December 2013, 10:54
  2. Sony LanC Program
    By l_gaminde in forum Code Examples
    Last Post: - 25th September 2009, 19:51
  3. Replies: 1
    Last Post: - 23rd May 2009, 10:22
  5. PIC16F684 Program question
    By Nicholas in forum mel PIC BASIC Pro
    Last Post: - 28th December 2006, 15:30
