Dc SSR circuit problem
Results 1 to 7 of 7
    Nov 2006
    Melbourne, Australia
    Angry Dc SSR circuit problem
    Hi everyone, I have a challenge (4 me) at which after many many attempts and killed a couple SSR. Attached is my circuit. The first part of the ssr works as it has a led indicator built in. (HFS40 05D-50D2T-L(555)). The IC1 pic 16f88 outputs on portb.0 to the SSR
    But cant get it to control the coil on a solenoid. I get no voltage on the output pins of the SSR.
    The circuit is to open and close FESTO pnumatic cylinder, confirm the cylinder is in position via FESTO reed switch.
    PLEASE can someone point me in the right direction
    Thanks in advance
    IF ITS STOCK IT WONT ROCK
    Talking Is it a joke ???
    Hi, Cooter
    Looks an industrial project, no ???
    BUT ... do you REALLY think someone will understand what is happening here ???
    just provide us a nice scheme ... WITH you SSR, if possible !
    BTW ... you should have a closer look at your SSR Datasheet ... but, it's just an idea ...
    Have you tested the SSR output with an LED?
    What are the specs of the solenoid? Flyback inplace?
    Wink
    Hi, Dave
    I think cooter did not understand his relay is to consider like a Power - optocoupler ...
    don't you ???
    Hi, Dave
    don't you ???
    Yep, that is why I ask about the LED to see if cooter understands the workings.
    Always start with blinky...
    Bombay, India
    Hey Cooter
    You need to use the output of the SSR as a switch in series with your load. You seem to have connected it across your 12 V supply. That is killing your SSR.
    Nov 2006
    Talking
    Thanks everyone, It works. So simple now I look back at it
  1. How can I get a PIC to switch 2.5V DC to my Opamp pin?
    By HankMcSpank in forum Schematics
    Last Post: - 9th January 2010, 23:04
  2. Replies: 24
    Last Post: - 1st December 2009, 09:01
  3. Circuit reliability issues
    By hkpatrice in forum mel PIC BASIC Pro
    Last Post: - 23rd November 2007, 15:55
  4. Replies: 3
    Last Post: - 29th October 2006, 10:16
  5. 1 slave 1 master 1 MAX232 1 problem ?
    Last Post: - 31st July 2005, 23:59
