Melexis
Results 1 to 5 of 5
Thread: Melexis
    Sep 2009
    Default Melexis
    I'm messin' with a MLX90614 IR sensor and wondered if anybody has any Picbasic code to interface with it? I guess any code that creates a SMBus communication format would work as well.
    It's a very interesting temperature sensor and Melexis actually provides assembly/C code but obviously I'd like to use PicBasic to do my development work...
    Looks like you should be able to use the I2C command.
    http://www.melexis.com/Asset/SMBus_c...Link_5207.aspx
    if you are careful
    Oct 2007
    The Netherlands
    You can set up the sensor to output PWM and then measure pulse length. Only trouble is, to set up the sensor you need the EVB90614 evaluation board and their somewhat buggy software. I did it this way and it worked okay for me.
    Sep 2009
    Default Sensor
    They have a sample program posted on their website in assembler. I've reviewed it and it seems pretty straight forward. I'll try to write some code in PicBasic using the I2C commands and post it here if I'm successful
    Sep 2009
    Default update on code
    Here's my subroutine. It worked like a charm!
    read_temp:
    sensortemp = 0
    reg = $07
    addr = 0
    I2CRead Tda, Tcl, addr, reg, [sensortemp.lowbyte, sensortemp.highbyte]
    I used a 18F6720 using a define of 4 mhz, with sensortemp defined as a word.
    reg and addr were defined as bytes. Tda and Tcl were pin assigments.
    reg $07 sets the sensor to send Object Temperature 1.
