I am sure I am missing something ...
Assume both input signals are 0 when idle.
If pinVar1 > 0 then ????
If pinVar2 > 0 then ?!?!
Yea that kindof what I was thinking, but the hard part is that the encorder will not be zeroed It could be in any of 4 places 00,01,11,10 I need a clean quick way of reading change. I can read the port shift left 6 back right 6 and get my two LSB's I need a way to sense change in either bit, or at least encoder direction of change ( this would be best ) then I could feed into my existing program and handle the output. So it would not have to mirror the encorder just give me the direction of movement Left, Right, for each click I would increment my existing program by one, up or down.
I know I not real clear but I really know what I want!! I think
Henrik shared some code here that may give you an idea or two.
http://www.picbasic.co.uk/forum/showthread.php?t=11683
Thank you I also did a search (dah) of the fourm and found that if I & the two bits it will give direction I will look all this over and repost if I don't get it.
thanks again
Just so I don't mess anyone up here,This is what will work for me.
Using Xor will give direction.
take the righthand bit of your old value xor it with the lefthand bit of the new value.
if your xor value is 0 the knob is turning clockwise
if your xor value is 1 the knob is turning counter_clockwise
