Hi everyone,Im real new to all thiss so I hope knowbody minds ifm my questions seem a little basic at times.
Im using a PIC16F876 for my projects and ive been messing around with small circuits moving servos,flashing led's on and off and using simple buton comands;but my goal in all of this is to trigger four ignition coils for a car engine in response to high signals from two optical triggers mounted on the distributor where the rotor arm used to be.
In place of a rotor arm I now have a four segment wheel and a single segment wheel with the triggers working off of it.The distributor has a reluctor in it which pulses the ignition amplifiers to fire the coils,and my plan is for my trigger signals to switch on transistors to supply the amps and coils with 12.v. in response to allow the sparks to happen.
I just seem to have thiss mental block with it all and I was hoping that maybe some of you petrol heads out there may have some pointers that I could use to get me started on the right track or even some places to look at other PIC Basic code which will get my head in the right place.
Thanks so much for any help.
O.T.
