Circuit design question, multiplexing 270 phototransistors
Results 1 to 7 of 7
Threaded View
  1. #2
    Dec 2005
    The DG408 is an 8 channel analog multiplexer. It needs 1 ADC pin and 3 control pins. It might be possible to use 8 of them, each with its own ADC pin, with their control lines in common but that still only gives you 64 channels so you would need 5 such setups (i.e. 5 PICs w/8ADC pins + 34 DG408s). That might still be better than using motorized rotary switches which get expensive and bulky. You could do it with 5 each PIC16F88 which only have 7 ADC pins. 5*7*8=280 total channelsYou can reduce the number of PICs to one by cascading the DG408s. This takes additional control lines and is a bit harder to visualize but (if my math is correct) you can have 448 channels with one PIC12F88 and 9 DG408s, needing 6 control lines.
    What type of output is needed?
  1. Circuit Design Question
    By bradb in forum mel PIC BASIC Pro
    Last Post: - 11th August 2009, 09:18
  2. Circuit reliability issues
    By hkpatrice in forum mel PIC BASIC Pro
    Last Post: - 23rd November 2007, 15:55
