Circuit design question, multiplexing 270 phototransistors
Results 1 to 7 of 7
    rschader's Avatar
    rschader Guest
    Default Circuit design question, multiplexing 270 phototransistors
    Seeking info on the best (smallest, cheapest) circuit and controller where I can monitor 270 photo transistors. Would want to be able to tell if all of them are receiving a certain level of light, or which ones are not receiving enough light. Planning on using a PIC controller. Mainly interested how to best multiplex that many inputs into the limited number of inputs.
    Dec 2005
    The DG408 is an 8 channel analog multiplexer. It needs 1 ADC pin and 3 control pins. It might be possible to use 8 of them, each with its own ADC pin, with their control lines in common but that still only gives you 64 channels so you would need 5 such setups (i.e. 5 PICs w/8ADC pins + 34 DG408s). That might still be better than using motorized rotary switches which get expensive and bulky. You could do it with 5 each PIC16F88 which only have 7 ADC pins. 5*7*8=280 total channelsYou can reduce the number of PICs to one by cascading the DG408s. This takes additional control lines and is a bit harder to visualize but (if my math is correct) you can have 448 channels with one PIC12F88 and 9 DG408s, needing 6 control lines.
    What type of output is needed?
    Dec 2005
    My math was wrong. Cascading would require 56 DG408s for 448 channels.
    Jun 2009
    Sc*nthorpe, UK
    I2C is the way I would go. Use PICs for the slaves.
    rschader, How fast are going to scan the matrix? What PIC are you intending on using? If it was me, I would switch the source for the phototransistors and use 1 a/d port. Less power and less to worry about as far as calibrating all of the a/d channels and multiple references with multiple PIC's.
    Dec 2005
    Reducing it to a single ADC pin would only require one more DG408 and three more control lines but it does complicate the switching logic, going from 6-bits (with 7 ADC pins) to 9-bits.
    40 DG408s + 1 PIC with 1 ADC pin and 9 control pins.
    However, there is only one ADC channel with a PIC - it's input is merely being switched internally so there''s no real difference between using all seven ADC pins on a PIC16F88 and using only 1 ADC and adding another DG408.
  1. Circuit Design Question
    By bradb in forum mel PIC BASIC Pro
    Last Post: - 11th August 2009, 09:18
  2. Circuit reliability issues
    By hkpatrice in forum mel PIC BASIC Pro
    Last Post: - 23rd November 2007, 15:55
