PIC and TCP/IP
Results 1 to 3 of 3
Thread: PIC and TCP/IP
    jscoulter's Avatar
    jscoulter Guest
    Default PIC and TCP/IP
    Hi all.
    I have been away from the PIC scene for a while and now I am thinking of a new project.
    What I want to do is create a project that takes Serial data and then fires it thru TCP to a waiting server.
    A Serial TO TCP converter.
    Is there a PIC micro that had TCP/IP built in? Or what options can I/ Should I look at.
    Thanks, Jeremy
    Sep 2005
    Campbell, CA
    If you are experienced, yes, there several ways to do it with Microchip parts. But if you are only doing a small quantity, you are better off with the serial-to-ethernet devices from Lantronix or Digi. Very little knowledge or work required. RJ45 on one end of the board, DB-9 on the other end.
    Charles Linquist
    Dec 2005
    Quote Originally Posted by jscoulter View Post
    See this thread
  1. PBPL and TCP/IP
    By edtp in forum Ethernet
    Last Post: - 4th March 2011, 20:35
  2. Adding TCP/IP Ethernet to PIC - how?
    By gtvmarty in forum Ethernet
    Last Post: - 10th December 2010, 19:55
  3. Replies: 1
    Last Post: - 16th September 2008, 17:27
  4. PBP TCP/IP stack and Webserver
    By rocketman in forum mel PIC BASIC Pro
    Last Post: - 11th July 2005, 23:30
  5. Are there TCP/IP stack/library for PBP?
    By charliez in forum mel PIC BASIC Pro
    Last Post: - 31st October 2004, 12:48
