Configuration error
Results 1 to 28 of 28
    Jan 2006
    New Hampshire, USA
    I did a read on the 12F675 and it came up "code protected". How did that happen? I thought default was not protected. How could I read the memory if it was protected? I suppose I will have to throw away the two that I tried to program. I hesitate to try a 3rd 12F675 but they are cheap, thank the Lord.
    Look at the program that your programmer uses. Some have a way to set the fuses there. If you have one like that find out how to disable that option. It is nothing but trouble.
    Oct 2006
    Edmonton AB Canada
    Dave,
    Unsure that this matters, but I had a heck-of-a fun time with an 833 chip last week, due in no small part to the programmer. Current numbers are:
    Programmer 4.31
    MCS 3.0.0.5
    PBPro 2.50c
    Microcode studio is an easy fix. The programmer should probably be upgraded, and unless somebody more literate than I takes issue, I'll say that you're ok with PBPro.
    There is a "configuration" window that shows up under the "view" menu in the programmer. I've never had an issue with it, it will over-write any settings you put in the code. Is it the best way? Who the heck knows. It can make your life miserable if you are trying to do something specific and not pay attention to it.....
    Hope that helps
    Gary
  1. Configuration bits and timing
    By Christos_K in forum mel PIC BASIC Pro
    Last Post: - 17th November 2012, 09:53
  2. Loop with two motor and 2 sensors
  3. Optimizing DIV
    Last Post: - 22nd September 2008, 05:58
  4. pbp245 compliation error
    By Woodzy in forum mel PIC BASIC Pro
    Last Post: - 25th July 2006, 06:59
  5. 16F88 Compile error
    By Toley00 in forum mel PIC BASIC Pro
    Last Post: - 2nd November 2005, 01:22
