Configuration error
Results 1 to 28 of 28
Threaded View
  1. #19
    Sep 2009
    Quote Originally Posted by Russ Kincaid View Post
    I did download the beta programmer and tried to program a 12F675 that had already been successfully programmed. First I read the memory; it was 3FFF in all locations. That was not correct but I tried to program it anyway. The process went smoothly and verified OK. I then read the memory; it was 3FFF all over. I clicked on the verify icon; it reports an error. Is this another IC for the dust bin?
    You can erase them don't throw them away all you have to do is open the pickit2 software and turn code protect off and then erase the chip.
    The best way to do it is place the 12f675 in a solderless bread board fire up the pickit2 and reset code protect.
    If it don't let you put a new chip in first let the pickit2 detect it then remove it and place you locked chip in then unlock and erase
    You don't have microcode set for the right chip is why this is happen. What happen to me is that it set for default which is 16f628 and I changed it to the 12f675 before I compiled it still built for the 16f628
    I then ended with a locked chip I then clean out the folder and started over saved the project as 12f675 from the start and it worked fine
  1. Configuration bits and timing
    By Christos_K in forum mel PIC BASIC Pro
    Last Post: - 17th November 2012, 08:53
  2. Loop with two motor and 2 sensors
  3. Optimizing DIV
    Last Post: - 22nd September 2008, 04:58
  4. pbp245 compliation error
    By Woodzy in forum mel PIC BASIC Pro
    Last Post: - 25th July 2006, 05:59
  5. 16F88 Compile error
    By Toley00 in forum mel PIC BASIC Pro
    Last Post: - 2nd November 2005, 00:22
