8 pin DIP w/6 outputs ?
Results 1 to 13 of 13
    Mar 2004
    The simple answer to that is, control 6 LED's separately with only a 8 pin DIP package.
    Dec 2005
    Mar 2004
    Quote Originally Posted by Sam View Post
    I have been searching Microchip.com and haven't found any 8 pin DIP PIC's with 6 output. The MCLR is always an input only, which I basically understand but is there any model with 6 outputs.
    Hi Dave,
    I figure (?) you're talking about tip 2 I/O multiplexing ? That may just work for my application. I'll take a close look at it now, it however means redesigning my PCB and changing the code.
    And wouldn't it leave 2 outputs to spare, GPIO.4 and .5 ?
    SS
    EDIT: or was it tip 3 ?
    Here is another option.
    http://www.picbasic.co.uk/forum/showthread.php?t=10200
    But it would be a complete redesign.
    Mar 2004
    Well that's very impressive that your 7 year old did some of the the work and the code ! And it's a very nice project, but it's not practical for my project as it must be on a 1" diameter single sided PCB.
    Thanks for the link anyway, it looks like the multiplexing will have to be the way to go for me.
    SS
    Dec 2005
    Yes, I meant Tip 2. It was past my bedtime - I meant to say it would leave an input pn free plus two input/output pins.
    Mar 2004
    Hey Dave,
    Thank you very much, that multiplexing completely solved my issue ! I never thought about doing it like that but once you see it (tip 2) it makes perfect sense. It's just what I needed and it's working great.
    You're a great asset to the forum and I really appreciate all your help,
    SS
    Dec 2005
    I'm surprised I remembered it. I had a copy of that PDF on a network HDD which failed a few weeks back but vaguely recalled it had several unconventional but simple methods for getting the most out of minimal hardware. I have a new, bigger NAS drive but had not grabbed a copy of the PDF until your post jogged my synapses.
    The Atmel AVR ATTiny12 allows you to use MCLR as an open drain output but its pinout is different.
    I think that is officially called "Charlieplexing" and is a method originally though up by someone from Maxim Semi. Check this webpage:
    http://en.wikipedia.org/wiki/Charlieplexing
    Tim Barr
  1. Is this a K Type sensor?
    Last Post: - 21st November 2009, 14:55
  2. DS1820 with 16f688
    Last Post: - 23rd May 2009, 06:07
    Last Post: - 13th December 2008, 18:11
  5. Another RTC, DS1287
    Last Post: - 12th December 2006, 18:07
