Problem compiling EasyHID code
Results 1 to 4 of 4
    PBP's old USB files can't be used with the new versions of MPASM.
    The new version of PBP 2.60 has new USB files that will work with it. But if you're trying to compile an older USB program ... you have to make changes to the files being included, and create a new Descriptor, because the one's from EasyHID don't work with 2.60.
    Consequently, until David updates EasyHID, it's "Broke".
    If you go back to an earlier version of MPLAB/MPASM then you can still compile the EasyHID or other old USB programs with PBP 2.50 or previous.
    meLabs has MPLAB 8.15a on their website.
    http://www.melabs.com/support/mplab_old_versions.htm
    Mar 2008
    Downgrading the MPASM solved the problem.
    Steveo2969's Avatar
    Steveo2969 Guest
    HI,
    I'm currently using PBP 2.50c with MPlab 8.15a and MicroCode Studio Plus 3.0.0.5 and I want to upgrade to PBP 2.60 and the latest version of MPlab but i'm wondering if the problem still exsists when trying to compile older USB EasyHID code?
  1. My first DT_INT code has a problem.....
    By E Kizer in forum mel PIC BASIC Pro
    Last Post: - 13th April 2009, 14:37
  2. Weird code problem
    By Navaidstech in forum mel PIC BASIC Pro
    Last Post: - 16th March 2009, 12:16
  3. Making Program Code Space your playground...
  4. problem with my code
    By civicgundam in forum mel PIC BASIC Pro
    Last Post: - 3rd February 2008, 02:52
  5. Servo Code problem
    By ALFRED in forum General
    Last Post: - 2nd March 2006, 04:30
