adcon0,adcon1
Results 1 to 5 of 5
Thread: adcon0,adcon1
    france
    Default adcon0,adcon1
    Hello
    I have an example program that melanie is very good.
    I have a problem with the port configuration registers and
    ADCON0 and ADCON1
    device 16f876a
    Trisa:% 00001110 'output RA0, RA1, RA2, RA3 input
    ADCON0 =% 11,000,000
    ADCON1 =% 00,000,111
    Thank you for your help
    Bombay, India
    ADCON0 and ADCON1
    device 16f876a
    Are you sure you are typing it as shown in Melanie's code? The way you've shown here will give compilation errors. Or maybe I don't understand your question.
    Trisa = %00001110
    ADCON0 = %11000000
    ADCON1 = %00000111
    france
    Hello
    This model melanie and I'll add my program routines.
    And I need to use the port and having output RA0 and RA1 RA2 RA3
    Input, and my question is about the ADCON registers?
    I do not configured.
    Thank you
    Quote Originally Posted by jonas2 View Post
    Hello
    <font color=red>I do not configured. </font color>
    Thank you
    Hello Jonas2,"I do not configured"means . . . you have changed from Melanie's code ?
    Anyway, to address your question, I hope. . .
    From the DATA SHEET:
    ADCON0 = %11000000
    bit 0 = 0 ADCON is turned off
    bit 1 = 0 unimplemented (not used) read as 0
    bit 2 = 0 A/D Go Done conversion not in progress
    bit 3 -5 = all zeros A/D channel select bits
    bit 5-7 = 11 FRC (clock derived from the internal A/D RC oscillator)
    ADCON1 = %00000111
    sets all ports to digital
    france
    Hello
    Thank you for your help, I'll keep the program melanie.
    But I would like to change the initialization of the RTC, and to do so USArt
    Send frame by rs232.je seeks a routine as an example.
    Thank you
