DS18s20 - negative teperature
Results 1 to 6 of 6
    Ceug2005's Avatar
    Ceug2005 Guest
    Default DS18s20 - negative teperature
    WHAT IS WRONG HERE ?!
    i heave 2 sensors DS18S20 in one wire network , 4,7 k resitor pullup,
    3 wires / Vcc = 5V , GND, data
    1.with positive temerature works OK.
    2.with negative teperature around 0°c is jumping from -655.11 to +88.xx , then i heave right data ,after some time is jumping again and again .....or is jumping from -655.11 to right data and back.
    PIC16F877 AT 4 MHZ
    count_remain_0 Var Byte ' sensor 0
    count_per_c_0 Var Byte ' sensor 0
    count_remain_1 Var Byte ' sensor 1
    count_per_c_1 Var Byte ' sensor 1
    TempC0 VAR WORD ' RAW Temperature readings sensor 0
    R_Temp0 VAR WORD ' RAW Temperature readings sensor 0
    TempC1 VAR WORD ' RAW Temperature readings sensor 1
    R_Temp1 VAR WORD ' RAW Temperature readings sensor 1
    Deg CON 223 ' Data to display Deg ° symbol
    Sign0 VAR BYTE ' +/- sign for temp display sensor 0
    Sign1
    'sensor 0
    OWOUT PortB.0, 1, [$55,$10,$BB,$40,$2C,$00,$08,$00,$F9, $44] ' match ROM & do temp conversion
    pause 50
    OWOUT PortB.0, 1, [$55,$10,$BB,$40,$2C,$00,$08,$00,$F9, $BE] ' match ROM & read scratchpad memory
    OWIN PortB.0, 2, [R_Temp0.Lowbyte, R_Temp0.Highbyte,skip 4,count_remain_0,count_per_c_0] '
    if R_Temp0.bit9 = 0 then 'temp pozitive
    sign0="+"
    TempC0 = (((R_Temp0>> 1) * 100) - 25) + (((count_per_c_0 - count_remain_0) * 100) / count_per_c_0)
    sign0="-" 'temp negative
    R_Temp0 = R_Temp0.lowbyte ^%11111111
    R_Temp0 = R_Temp0.lowbyte + 1
    R_Temp0 = R_Temp0.lowbyte>> 1
    lcdout $FE , 1 ,sign0,DEC TEMPC0 DIG 3,DEC TEMPC0 DIG 2 ,".",DEC TEMPC0 DIG 1,DEC TEMPC0 DIG 0 ,Deg,"C","
    have a look on this link
    Ceug2005's Avatar
    Ceug2005 Guest
    Talking
    Ohhh Ty Steve.
    If you want to buy a pizza , i dont send you to rent a car.
    i ask what is wrong not to use DIV32 with DS18B20.
    like you see i use DS18s20.
    anj's Avatar
    anj Guest
    One thing to watch out for when reading a DS18s20 is that they slow down with colder temps
    The max timeout they specify to do a temp conversion is 750ms. Reading data before that can result in corruption
    Yr code has
    pause 50
    thus you are only allowing 50ms.
    Setting this higher, or using a loop to check for the "done" bit being set will probably stabilise it at the lower temps.
    Ceug2005's Avatar
    Ceug2005 Guest
    Lightbulb
    TY anj
    all works fine with 750 - 800 ms.
    And in AC Electrical caracteristics - data sheet is specified
    " t_CONV max 750 ms ".
    TY again
    Ceug2005's Avatar
    Ceug2005 Guest
    ds1820-report.pdf by Dalas semi
  1. negative pulse I/O pin how to?
    By rickyD in forum General
    Last Post: - 13th June 2008, 06:48
  2. DS18S20 reading negative temperature
    By srob in forum mel PIC BASIC Pro
    Last Post: - 28th December 2007, 22:21
  3. DS18S20 displays wrong temperatures
    By Shozo Kanamori in forum mel PIC BASIC Pro
    Last Post: - 6th August 2007, 04:18
  4. Reading (ADC) negative current
    By sougata in forum mel PIC BASIC Pro
    Last Post: - 21st November 2006, 18:38
  5. 16F877, DS18S20 and Serial Comm Problem
    By YellowTang in forum mel PIC BASIC Pro
    Last Post: - 26th April 2004, 11:36
