Accessing MultiByte Variables in Assembler
Results 1 to 6 of 6
    Jul 2008
    TURKIYE-KONYA
    MYVAR      VAR WORD
    MYVAR_L   VAR MYVAR.lowbyte
    MYVAR_H   VAR MYVAR.highbyte
    CLRF    _MYVAR_L
    CLRF    _MYVAR_H
    YOU CAN USE THIS. I USE THIS METHODE WITH LONG VARIABLES. THERE IS NO PROBLEM.
    Aug 2009
    Default Thanks!
    Thank you very much! I'm surprised I didn't think of that.
    Now comes the next question.
    Is there a "banksel" function equivalent in PM assembler?
    Jul 2008
    TURKIYE-KONYA
    NO THERE ISNT ANY EQUIVALENT FUNCTION.
    I KNOW THAT , PIC BASIC PRO MAKES THE BANKSEL FUNCTION ITSELF.
    Aug 2009
    Default Hmm....
    I'm trying to use inline Assembler, but I use multiple arrays which means I need to address multiple banks. How can I tell which bank a given array is stored in?
    Also, I'm not certain how you mean that banksel is produced by PM itself. I'm using 2.5, and it's choking on errors - all related to my attempts to use banksel.
    This may all be simplified if I just specify which bank I want each variable in.
    Quote Originally Posted by The Altruist
    I'm having trouble figuring out how to access the High and Low Bytes of 16-bit Words in Assembler.
    MyWord  VAR WORD BANK0
        movf     _MyWord,w      ; this gets the LowByte
        movwf    PORTB
        movf     _MyWord + 1,w  ; this gets the HighByte
        movwf    PORTC
    You can use the CHK?RP macro to locate the bank for any variable.
    But if you're accessing arrays, it's probably better to use an FSR/INDF.
  1. WRITECODE stores wrong 14-bit word values in FlashMEM
    By BobPigford in forum mel PIC BASIC Pro
    Last Post: - 26th June 2009, 04:35
  2. PIC assembler forum?
    By Lajko in forum Off Topic
    Last Post: - 29th September 2008, 05:34
  3. Assembler problem
    By om3bc in forum mel PIC BASIC Pro
    Last Post: - 25th March 2008, 19:12
  4. Variables not appearing in Watch Window MPLabv7.3
    Last Post: - 16th June 2006, 14:36
  5. Problems with variables
    By egberttheone in forum mel PIC BASIC Pro
    Last Post: - 15th December 2004, 18:37
