Warning and Message
Results 1 to 5 of 5
    Dec 2005
    Default Warning and Message
    PBP2.50
    MPASM
    PIC12F509
    I'm seeing...
    • Warning[202] ... Argument out of range. Least significant bits used.
      Message[306] ... Crossing page boundary -- ensure page bits are set.
    What do they mean? What, if anything, need I do?
    '=======================| RF RECEIVER |=========================
    'MR26X.BAS
    'PIC12C509A @ 4MHz          529 words		uses MPASM
    'Pin 1 - Vdd
    'Pin 2 - GPIO.5
    'Pin 3 - GPIO.4
    'Pin 4 - GPIO.3
    'Pin 5 - GPIO.2 RS232 output @ 9600bps
    'Pin 6 - GPIO.1 Receives up to 48 bits of PDM/PWM RF with lead-in of 2-9mS
    'Pin 7 - GPIO.0
    'Pin 8 - Vss
    'TMR0 1:64 30=1.9mS, 145=9.3mS - 1:16 50=0.8mS, 94=1.5ms, 155=2.5ms
    @ __config _IntRC_OSC & _WDT_ON & _MCLRE_ON & _CP_OFF
    DEFINE OSCCAL_1K 1
    RF      VAR 	byte[6]
    i       VAR 	byte
    bytes	VAR	byte
    sof  	VAR 	byte
            SerOut GPIO.2,2,["MR26X",13,10]
            SerOut GPIO.2,2,["Copyright © 2009  dlh",13,10]
    init:	RF[0]=0:RF[1]=0:RF[2]=0:RF[3]=0:RF[4]=0:RF[5]=0
    	OPTION_REG=%01000101		'TMR0 1:64 prescaler, no PU
            While !GPIO.1:Wend		'wait rising edge
            TMR0=0		                'clear TMR0
            While GPIO.1:Wend               'wait falling edge
            sof=TMR0			'read TMR0
            If (sof<30) Then init		'1920µS
            If (sof>145) Then init		'9280µS
            OPTION_REG=%01000011		'TMR0 1:16 prescaler, no PU
            TMR0=0				'reset TMR0
            i=0
            Repeat
              While GPIO.1                  'wait falling edge
    	    If TMR0>155 Then break  	'2480µS
              Wend				'falling edge
              While !GPIO.1                 'wait rising edge
              Wend				'rising edge
              If (TMR0<50) Then init	'800µS
              If (TMR0>94) Then		'1500µS
                RF.0(i)=1
              EndIf
              TMR0=0
              i=i+1
            Until (i>47)
    break:  If (i<12) Then init
            bytes=i/8
            If i//8 Then
    	  bytes=bytes+1
            EndIf
            SerOut GPIO.2,2,[i]
            For i = 0 to bytes-1
      	  SerOut GPIO.2,2,[RF[i]]
            Next
            SerOut GPIO.2,2,[32,sof,13,10]
            GoTo init
    dhouston, I would look at the .LST file and find the occurance of "warning" and then see what variable it is trying to manipulate. This should give you a clue...
    Dec 2005
    Here's the .LST file section...
    00F9   0918               M         call    SEROUT
                          00078         SEROUT?C        0FFA9h
    Warning[202]: Argument out of range.  Least significant bits used.
    00FA   0CA9               M         movlw   0FFA9h
                              M         L?CALL  SEROUT
    By commenting out each SerOut instance (one-by-one) and recompiling, I isolated it to the copyright message. Without it, both the warning and message go away.
    I'll have to wait until Digikey ships my 12F509 chips to test it.
    dhouston , I just ran your code and if you get rid of the copyright character the code compiles... Where are you getting the copyright symbol anyways? I don't think the assembler understands it....
    Dec 2005
    It was copied and pasted from my source code for an Atmel AVR compiler. The ASCII chart in Appendix D of the PBP manual only goes to 127 so any extended character is likely to cause this. © is ascii 169 (depending on the font).
    EDIT: The same copyright line compiles and works OK with a 12F629. It must be a limitation of the 12-bit cores. Anything greater than Ascii 126 causes the error.
  1. PIC16F690 PBP boundary crossing warning message
    Last Post: - 9th May 2008, 11:17
  2. Advice please - Warning message
    Last Post: - 23rd January 2007, 13:20
  3. Micro Code Studio - Warning message
    Last Post: - 17th November 2006, 21:17
  4. MicroCode Studio Boundary Warning Message
    By coyotegd in forum mel PIC BASIC Pro
    Last Post: - 16th March 2006, 09:13
  5. warning message
    By pic beginner in forum mel PIC BASIC Pro
    Last Post: - 23rd July 2004, 02:53
