4094 Please Help
Results 1 to 7 of 7
    Sep 2009
    Default 4094 Please Help
    hello
    I wrote this for the 16F877 for 2 4094
    The first 4094 works correctly the second not
    What I do wrong please help
    thanks
    INCLUDE "modedefs.bas"
    TRISC = %00000000
    symbol clock=portc.0
    symbol data_pin=portc.1
    symbol strb=PORTc.2
    symbol data_pin2=portc.3
    high strb
    high data_pin 'FOR STROBE HIGH
    ShiftOut data_pin,clock,1,[%11000011]
    low strb
    low data_pin
    high strb
    high data_pin2
    ShiftOut data_pin,clock,1,[%10000001]
    low strb
    low data_pin2
    pause 2000
    [IMG][/IMG]
    Maybe add this to your code?
    ShiftOut data_pin2,clock,1,[%10000001]
    Sep 2009
    Hi mackrackit
    Thank's for your thoughts
    I tried ShiftOut data_pin2,clock,1,[%11000011] but not working properly U2
    I would recomend seperate control pins for the second 4094 (OE and STRB) with common CLK.
    Or even better, use the two 4094 in chain and feed data to the second Data in out of the first 4094, using common controls as you do now.
    Ten you have to send 16bits of course, before activate outputs.
    Sep 2009
    Hi Ioannis
    You're right it works perfectly
    View circuit and program to Picbasic
    Thank you very much my friend Ioannis
    DEFINE SHIFT_PAUSEUS 100
    TRISC = %00000000
    symbol strb1=PORTc.2
    symbol strb2=PORTc.3
    alarm var word
    miso var byte
    alarm = %1001100111010111
    miso = alarm>>8
    high strb1
    ShiftOut data_pin,clock,0,[alarm\8]
    low strb1
    high strb2
    ShiftOut data_pin,clock,0,[miso]
    low strb2
    pause 2000
    Jul 2008
    TURKIYE-KONYA
    Default 1 data , 1 strb , 1 clk and dozens 4094
    HI DOVEGROUP.
    YOU DONT NEED TO USE EXTRA PINS FOR ANOTHER 4094.YOU CAN USE SAME PORTS.
    YOU CAN CONNECT "Qs DATA OUT" TO ANOTHER 4094.
    include "modedefs.bas"
        ADCON1  = 7
        STRB  VAR  PORTC.2
        DAT   VAR  PORTC.1
        CLK   VAR  PORTC.0
        OUTPUT STRB
        OUTPUT DAT
        OUTPUT CLK
        DATA_1  VAR BYTE
        DATA_2  VAR BYTE
        DATA_1 = %11000011
        DATA_2 = %10000001
        MAIN :
        SHIFTOUT DAT , CLK , 1,[DATA_2 , DATA_1]
        STRB = 1  : PAUSEUS 100 :  STRB = 0
    GOTO MAIN
  1. 16F877 and 4094 please help
    By dovegroup in forum mel PIC BASIC Pro
    Last Post: - 21st May 2014, 14:22
