hey sorry need some help on this... been working with timer1 to make leds blink from someone code example in the past. unforunately im a bit stuck
define OSC 20
TRISA = 0
TRISB = 0
PORTA = 0
PORTB = 0
T1CON = %00110001 ' 0.524ms
TMR1IF VAR PIR1.0 ' Overflow bit of Timer1.
Output1 VAR PORTB.1 ' Blink 6secs.
Output2 VAR PORTB.0 ' Blink 0.5secs.
PreLoad VAR WORD
TimeCount VAR BYTE
TimetoBlink VAR BYTE
PreLoad = 0 ' to get 500ms.
TMR1H = PreLoad.HighByte
TimeCount = 0
TimetoBlink = 12 '12 = 6secs.
PAUSE 50 ' OSC to Settle.
Start:
IF TMR1IF THEN Blink
GOTO Start
Blink: 'Each int is 0.500 sec.
TMR1L = PreLoad.LowByte ' Load the timer with preload value.
TimeCount = TimeCount + 1 ' Count interrupts.
Output2 = Output2 ^ 1 ' Toggle fast blinking output.
IF TimeCount = TimetoBlink THEN '6Secs ON, 6secs OFF.
TimeCount = 0
Output1 = Output1 ^ 1
TMR1IF = 0 ' Clear TMR1 int. flag.
GOTO Start
unfortunately the blinks are far too fast.... about 8 to 10x too fast.
my pic is oscillating at 20mhz so i thought id just use that internal oscialltion. when u choose that oscillator it does Fosc/4 so its at 5mhz. with a word size timer1 i can measure up to 65536 ticks; with a 1:8 prescaler on that only takes about 0.7 seconds or something to complete. how do i get it so it will be 6 seconds? cant change prescaler anymore... and preloader wont make a difference since it only speeds up the cycle. i think anyway
any help on this? thanks
