How to set GPIO.5 as output ?
Results 1 to 14 of 14
    Mar 2004
    Default How to set GPIO.5 as output ?
    I have been trying everything I can think of to set GPIO.5 of a 12F675 to work properly as an output and no matter what I do it remains HIGH all the time.
    Can you tell me what I must set to have it work correctly ? I have scoured the data sheets and I'm obviously missing it.
    Thx.
    Oct 2006
    Edmonton AB Canada
    Sam,
    Using a set of instructions like:
    output GPIO.5
    Led1 var GPIO.5
    low Led1
    as a setup, will allow you to set the output high or low at your liesure.
    Cheers
    Gary
    You need to do a little more than that...
    Datasheet is your friend... use it...
    First... TRISIO will set INPUT (1) or OUTPUT (0)... so...
    TRISIO=%01111 ' example will set GPIO.5 as OUTPUT and all the others as INPUT...
    then always check for COMPARATORS... now GPIO.5 doesn't have any, but if you are not going to use them, switch them OFF, because by the time you start playing with GPIO.0, GPIO.1 and GPIO.2, you'll be back on this forum asking us why they don't work... so add...
    CMCON=%00000111 ' see Datasheet Section 6
    Next check that you have your A/D's switched off... again, they don't affect GPIO.5, but if you are not going to use them, they can impact on the other GPIO's so disable the A/D with the instruction...
    ANSEL=%00000000 ' see Datasheet section 7
    Next GPIO.5 and GPIO.4 is where you normally connect your Xtal or Resonator... if you are going to use those pins for I/O then you probably want to enable the INTERNAL OSCILLATOR... so use the command (if you are using PBP's default PM Assembler)...
    @ DEVICE pic12F675, INTRC_OSC_NOCLKOUT ' System Clock Options (Internal)
    Finally, if you want to use GPIO.3 as INPUT (rather than have to connect MCLR externally), then have the PIC handle MCLR internally for you with the setup...
    @ DEVICE pic12F675, MCLR_OFF ' Master Clear Options (Internal)
    A good set of CONFIGURATION SETUP's for playing with the 12F675 are...
    	'	PIC Defines
    		' System Clock Options (Internal - GPIO.4 and GPIO.5 available for I/O)
    	@ DEVICE pic12F675, WDT_ON
    		' Watchdog Timer
    	@ DEVICE pic12F675, PWRT_ON
    		' Power-On Timer
    		' Master Clear Options (Internal - GPIO.3 available for INPUT)
    	@ DEVICE pic12F675, BOD_ON
    		' Brown-Out Detect
    Your PIC's GPIO.5 should now be working with Gary's code... if it isn't, check you've not shorted GPIO.5 against the adjacent Vdd pin which could cause it to hold HIGH.
    Mar 2004
    I knew I should have posted my code but I was on a different computer at the time. The first is the program I have tried, with it, GPIO.4 works properly but GPIO.5 remains HIGH always. There's no short btwn any pins, I'm using a clean breadboard.
    POR
    ADCON0=0
    VRCON=0
    OPTION_REG.5=0
    OPTION_REG.7=1
    CMCON=7
    TRISIO=%00001000
    LED1 var GPIO.0
    LED2 VAR GPIO.1
    LED3 VAR GPIO.2
    LED4 VAR GPIO.4
    LED5 VAR GPIO.5
    PAUSE 50
      loop:                  'scroll test pattern
    high led1
    pause 75
    LOW LED1
    PAUSE 50
    high led2
    PAUSE 75
    LOW LED2
    PAUSE 50
    HIGH LED3
    PAUSE 75
    LOW LED3
    PAUSE 50
    high led4
    PAUSE 75
    LOW LED2
    PAUSE 50
    HIGH LED5
    PAUSE 75
    LOW LED3
    PAUSE 50
    goto loop
    The code below is based on your reply (which I appreciate) and it makes GPIO.4 and GPIO.5 remain HIGH at all times. I have tried compiling in both PM and mpasm. Also, I have the MCLR disabled in EPIC'c configuration. I'm not using an ext. osc.
    TRISIO=%00000
    CMCON=%00000111
    ANSEL=%00000000
    LED1 var GPIO.0
    LED2 VAR GPIO.1
    LED3 VAR GPIO.2
    LED4 VAR GPIO.4
    LED5 VAR GPIO.5
    PAUSE 50
    high led1
    pause 75
    LOW LED1
    PAUSE 50
    high led2
    PAUSE 75
    LOW LED2
    PAUSE 50
    HIGH LED3
    PAUSE 75
    LOW LED3
    PAUSE 50
    high led4
    PAUSE 75
    LOW LED2
    PAUSE 50
    HIGH LED5
    PAUSE 75
    LOW LED3
    PAUSE 50
    goto loop
    So I must be doing something wrong or missing something ? If I remove ANSEL GPIO.4 works ???
    This is just a way for me to learn to use GPIO.4 and 5 and plan to use them in another program later.
    Thanks for the help !
    I see
    HIGH LED5
    but I do not see
    LOW LED5
    Maybe I am missing something???
    Mar 2004
    I see
    HIGH LED5
    but I do not see
    LOW LED5
    No, you're not missing anything, that was it ! Good job on catching that, I can't believe how many times I looked at that and never saw it. I still had to remove ANSEL to get GPIO.4 to work but it's all good now.
    Thank you for pointing that simple (read STUPID) mistake out, and thanks Melanie and Gary,
    Sam
    Apr 2007
    I see
    HIGH LED5
    but I do not see
    LOW LED5
    There is no LOW LED4 either.....................
    Andy
    Dec 2003
    Wichita KS
    Default You should sticky this. . ..
    	'	PIC Defines
    		' Watchdog Timer
    		' Power-On Timer
    		' Brown-Out Detect
    Hello Melanie!
    Long time no see. . .
    It has been a while since I have been on, but I saw this response... I don't remember if there was a "sticky" or a such a good definition in the FAQ side of this forum of chip headers / switches and why.
    I ran into a situation of two chips about 1 month ago. Had them working together, then suddenly one stopped. Could not for the life of me figure out what happened. It just seemed to work for about 15 seconds, get "soft", then die. Soon it stopped working all together. AFter running in circles,I found I guess I blew one of the pins somehow. I only switched my code to another pin and it has been working since.
    Dwayne
    Ability to Fly:
    Pilots that are Flying:
    Jul 2015
    Default Re: How to set GPIO.5 as output ?
    write this code:
    T1CON.3 = 0
    @__config _INTRC_OSC_NOCLKOUT & _MCLRE_OFF
    		CMCON = 7
            'VRCON = 0
            'WPU = 0                 'no wake pullup
            'IOCB = 0                'no int. on change
            ANSEL = %00000000      '16tosc gpio0 input analogico
            ADCON0 = 0      'right just , Vref=Vdd , ch.0 , A/D on
    	T1CON = %11110101
    	T1CON.3 = 0
    'OPTION_REG.7 = 0
        TRISIO=%001000
    LEDT1	var GPIO.1
    LEDT2	var GPIO.2
    B0	var byte
    B1	var byte
    B2	var byte
    I	var byte
    N	var byte
    O	var byte
    S1	var byte
    S2	var byte
    S3	var byte
    start:
    	high GPIO.4
    	high GPIO.5
    	low GPIO.4
    	low GPIO.5
    goto start
    Jul 2015
    write this code: T1CON.3 = 0
    CMCON = 7
    'VRCON = 0
    T1CON = %11110101
    T1CON.3 = 0
    'OPTION_REG.7 = 0
    TRISIO=%001000
    LEDT1 var GPIO.1
    LEDT2 var GPIO.2
    Power var GPIO.5
    B0 var byte
    B1 var byte
    B2 var byte
    I var byte
    N var byte
    O var byte
    S1 var byte
    S2 var byte
    S3 var byte
    high power
    start:
    ' gosub light
    high GPIO.4
    high GPIO.5
    low GPIO.4
    low GPIO.5
    goto start
    nice digging out !!!
    - 10th September 2009, 16:40
    hope he has found a solution ... +/- 6 years later ....
    Jul 2015
    Quote Originally Posted by Acetronics2 View Post
    Yes, I realized.
    But my goal was to show the correct solution
    Because of the low price and economy,
    12f675 in many applications
    You realize the T1CON.3 BOD /POR is 0 by default . . .
    Name:  12F675 T1CON.jpg
  1. Interruptus Frustratus
    Last Post: - 17th April 2009, 21:36
  2. 16F628A - Stops if release power switch.
    By dene12 in forum General
    Last Post: - 14th February 2009, 08:57
  3. Help with sound command in 2 programs
    Last Post: - 5th July 2007, 21:36
  4. Serious Serial Situation Setbacks...
  5. error on compiling
    By parker in forum mel PIC BASIC Pro
    Last Post: - 16th June 2005, 15:31
