24Cxx copier with PIC 16F84A
Results 1 to 8 of 8
    Sep 2009
    Quote Originally Posted by phoenix_1 View Post
    Define variable as byte
    Make loop from 0 to 255
    Read first eeprom and put result to your variable
    write that variable to second eeprom in same address
    go to loop for full range of 256 location (24C02).
    For 24C02 is from address 0 to address 255.
    if loop come to end of count all is finished.
    Use I2C command to read and write EEPROM and make different I2C address
    for 1st and second EEPROM by hardware pin setup.
    Regards Robert
    what u have schematic please share here brother
    Look at the data sheet and the PBP manual. Everything you need is there.
    Good luck getting someone to do your school work for you.
    Sep 2009
    i have schematic Pic16F84A for eeprom 24Cxx copier now (in attachment)but i dizzy source code for schematic here.u can help me make source code.thanks
    May 2007
    Republic Serbia
    Quote Originally Posted by the_kid25 View Post
    Maybe u need to buy some good programator for EEPROM's ?
    Oct 2013
    Default Re: 24Cxx copier with PIC 16F84A
    i have schematic pic16f84a for eeprom 24cxx copier now (in attachment)but i dizzy source code for schematic here.u can help me make source code.thanks
    :020000001728bf
    :020008000900ed
    :04000c0043346f34d6
    :100010007034693465347534723420346434653432
    :100020002034323434344334783478340034831612
    :10003000083085001f308600ff3081008312ff30ba
    :10004000850086008d0197018320970a971d2b2834
    :10005000061786122d280613861606091f399600e4
    :100060009301940110301606031d382893154f286c
    :1000700008301606031d3e2813154f2804301606b7
    :10008000031d442893144f2802301606031d4a28e6
    :1000900013144f2801301606031d242894178617c1
    :1000a00006178616851d0d158f019001101f8613ea
    :1000b000101b8617051e8028051d8028051c80281a
    :1000c000142197200e0895000d1c80281621a320ce
    :1000d0000d1c80280d19732897200d1c80281508e9
    :1000e0000e06031d8028900a03198f0a14081006b3
    :1000f000031d562813080f06031d56288612812853
    :10010000061386178228193091008828fa3091004a
    :10011000c830920000000000000000000000000055
    :1001200000000000920b8a28910b88280800b2205a
    :10013000be200f0d0e39a138cf20f120e0208e0017
    :100140000321c7200800b2200e08cf20f120c720cd
    :100150000d1cb128be20a030cf20f120c7200d1cdf
    :10016000aa280800be200f0d0e39a038cf20f1209c
    :100170000d1cbd281008cf20f12008000a2105160b
    :100180001821051218210f211821051608000f212a
    :10019000051218210a2118210516182108009100be
    :1001a000083092000f21911f0512911b051618218e
    :1001b0000a2118210f21910d920bd2280516080053
    :1001c0000830920091010f21051618210a211821eb
    :1001d000910d1110051a1114920be3280f2111082b
    :1001e000080005160f2118210a2118210d10051edf
    :1001f0000d140f2108000f21051218210a211821c2
    :100200000f21051608000f21051618210a211821b3
    :100210000f2108008d1c05158d18051408008d1c74
    :1002200005118d18051008008d1008008d140800a8
    :0402300000000800c2
    :084000000200000000000000b6
    :02400e00f13f80
    :10420000280063002900200050006900650072004a
    :1042100072006500200043004f004c002c0020007d
    :104220006d00610072007300200032003000300029
    :1042300031002c0020005600200031002e003000fc
    :10424000530069007400650020007700650062007b
    :104250003a00200068007400740070003a002f00db
    :104260002f007700770077002e0063006f006c004e
    :1042700032003000300030002e006f007200670006
    :00000001ff
    Aug 2003
    Did one eleven yrs back
    Might have been my first PBP program.
    I left this note in the project folder:
    This hex expects normaly closed switches for Copy and Verify.
    The LEDs need their polaritys reversed and are to be tied to +5volts
    instead of ground for this hex also.
    ' 24LC16B SERIAL EEPROM DUPLICATOR / ERASER
    ' (c) Brek Martin 2002!
    pause 100                                     'breif pause at startup
    INCLUDE "modedefs.bas"                        'include serial modes
    B0 var byte                                   'set up variables
    B1 var byte                                   'B0, B1 & B2 as bytes
    B2 var byte
    addr var byte                                 'set up address & chip
    chip var byte                                 'variables for EEPROM
    B0 = 0                                        'clear copy buffer
    B1 = 0                                        'clear verify buffer
    trisb.0 = 1                                   'set button pins as inputs
    trisb.3 = 1
    fird:
    onel:
    IF portb.3 = 1 THEN twol                      'checking for first of two buttons
    '                                              at startup
    GOSUB pron
    GOSUB pron
    GOSUB pron
    GOSUB pron
    GOSUB pron
    GOSUB pron
    GOSUB pron
    GOSUB pron
    GOSUB pron
    GOSUB pron
    GOSUB pron
    comd:
    IF portb.3 = 1 THEN dupl
    IF portb.0 = 1 THEN eras
    goto comd
    dupl:
    chip = 158                                    'set chip variable to the
    '                                              value of first location minus 2
    rone:
    chip = chip + 2                               'add 2 to the chip variable
    IF chip = 176 THEN rnin                       'check for last chip location
    addr = 0
    aone:                                         'go back here every 256 bytes
    high portb.1                                  'turn source LED on
    low portb.1                                   'and off again
    portb.1 = 0
    I2CREAD porta.0,porta.1,chip,addr,[B0],eror   'read the byte from source EEPROM
    'serout2 portb.7,16780,[hex B0," "]            'send byte out serial port
    I2CWRITE portb.4,portb.5,chip,addr,[B0],eror  'write the byte to target EEPROM
    pause 15                                      'wait for the write to complete
    high portb.2                                  'turn target LED on
    low portb.2                                   'and off again
    I2CREAD portb.4,portb.5,chip,addr,[B1],eror   'read byte back from target EEPROM
    IF B0 != B1 THEN verr                         'verify the copied byte
    IF addr = 255 THEN rone                       'check for last address of each location
    addr = addr + 1                               'add 1 to addr variable for next read
    goto aone                                     'go back for next read
    rnin:
    serout portb.7,n2400,[" Copy completed!"]
    GOSUB cpyc
    GOSUB cpyc
    GOSUB cpyc
    GOSUB cpyc
    GOSUB cpyc
    GOSUB cpyc
    goto fnsh
    eror:                                         'label to jump to if error is detected
    serout portb.7,n2400,[" A read/write error occured !"]
    GOSUB eled
    GOSUB eled
    GOSUB eled
    GOSUB eled
    goto fnsh
    verr:
    serout portb.7,n2400,[" A verify error occured !"]
    GOSUB eled
    GOSUB eled
    GOSUB eled
    GOSUB eled
    GOSUB eled
    goto fnsh
    eras:
    B0 = 0                                        'value of first location minus 2
    B1 = 0                                        'reset copy and verify buffers
    rtwo:
    IF chip = 176 THEN rten                       'check for last chip location
    addr = 0
    atwo:                                         'go back here every 256 bytes
    low portb.2                                   'turn LED on
    I2CWRITE portb.4,portb.5,chip,addr,[B0],eror  'write B0 to EEPROM (B0 = 0)
    pause 15                                      'wait for write to complete
    I2CREAD portb.4,portb.5,chip,addr,[B1],eror   'read the byte back in
    IF B0 != B1 THEN verr                         'verify the byte has zero value
    high portb.2                                  'turn LED off
    IF addr = 255 THEN rtwo                       'check for last address of each location
    goto atwo                                     'go back for next read
    rten:
    serout portb.7,n2400,[" Erase completed!"]
    GOSUB cpyc
    GOSUB cpyc
    GOSUB cpyc
    GOSUB cpyc
    GOSUB cpyc
    GOSUB cpyc
    fnsh:
    goto comd                                     'go back and check for button push
    '                                  >>>>>>>>>>>>and now all the gosub LED sequences
    pron:
    low portb.1                                   'display power on LED sequence
    pause 75
    low portb.2
    pause 75
    high portb.1
    pause 75
    high portb.2
    pause 75
    cpyc:                                         'start copy completed LED sequence
    low portb.1
    pause 250
    low portb.2
    pause 250
    high portb.1
    pause 250
    high portb.2
    pause 250
    eled:                                         'start error LED sequence
    low portb.1
    low portb.2
    HIGH portb.1
    HIGH portb.2
    twol:
    IF portb.0 = 1 THEN thrl                      'checking for second of two buttons
    goto comd                                     'at startup
    thrl:                                         'custom sequence starts here
    low portb.1                                   'start LED sequence for early command
    I2CWRITE portb.4,portb.5,164,62,["T"],eror    'EDIT SOME CUSTOM CODE HERE
    pause 20
    I2CWRITE portb.4,portb.5,164,61,["U"],eror
    pause 20
    I2CWRITE portb.4,portb.5,164,60,["R"],eror
    pause 20
    I2CWRITE portb.4,portb.5,164,150,["T"],eror   'AND HERE
    pause 20
    I2CWRITE portb.4,portb.5,164,149,["U"],eror
    pause 20
    I2CWRITE portb.4,portb.5,164,148,["R"],eror
    pause 20
    gosub cpyc                                     'goto the LED sequence
    gosub cpyc
  1. PIC 16F84A and 7segment LED dispay
    By select in forum mel PIC BASIC Pro
    Last Post: - 21st November 2007, 22:01
  2. Slot Car timer with pic 16f84a
    By Snap in forum Serial
    Last Post: - 5th July 2007, 05:58
  3. ICSP using a 16F84a to program 24CXX
    By aftab in forum mel PIC BASIC
    Last Post: - 8th April 2007, 12:39
  4. send and receive data using pic 16f84a
    By PoTeToJB in forum Serial
    Last Post: - 25th February 2006, 15:47
