24Cxx copier with PIC 16F84A
Results 1 to 8 of 8
    Sep 2009
    Default 24Cxx copier with PIC 16F84A
    i need schematic copier for 24Cxx with microntroler PIC16F84A.share here please with source code for PIC16F84A.thaks for all
    May 2007
    Republic Serbia
    Default For start explanation of how to
    Quote Originally Posted by the_kid25 View Post
    Define variable as byte
    Make loop from 0 to 255
    Read first eeprom and put result to your variable
    write that variable to second eeprom in same address
    go to loop for full range of 256 location (24C02).
    For 24C02 is from address 0 to address 255.
    if loop come to end of count all is finished.
    Use I2C command to read and write EEPROM and make different I2C address
    for 1st and second EEPROM by hardware pin setup.
    Regards Robert
    Sep 2009
    Quote Originally Posted by phoenix_1 View Post
    Regards Robert
    what u have schematic please share here brother
    Look at the data sheet and the PBP manual. Everything you need is there.
    Good luck getting someone to do your school work for you.
    Sep 2009
    i have schematic Pic16F84A for eeprom 24Cxx copier now (in attachment)but i dizzy source code for schematic here.u can help me make source code.thanks
    May 2007
    Republic Serbia
    Maybe u need to buy some good programator for EEPROM's ?
    Oct 2013
    Default Re: 24Cxx copier with PIC 16F84A
    i have schematic pic16f84a for eeprom 24cxx copier now (in attachment)but i dizzy source code for schematic here.u can help me make source code.thanks
    :020000001728bf
    :020008000900ed
    :04000c0043346f34d6
    :100010007034693465347534723420346434653432
    :100020002034323434344334783478340034831612
    :10003000083085001f308600ff3081008312ff30ba
    :10004000850086008d0197018320970a971d2b2834
    :10005000061786122d280613861606091f399600e4
    :100060009301940110301606031d382893154f286c
    :1000700008301606031d3e2813154f2804301606b7
    :10008000031d442893144f2802301606031d4a28e6
    :1000900013144f2801301606031d242894178617c1
    :1000a00006178616851d0d158f019001101f8613ea
    :1000b000101b8617051e8028051d8028051c80281a
    :1000c000142197200e0895000d1c80281621a320ce
    :1000d0000d1c80280d19732897200d1c80281508e9
    :1000e0000e06031d8028900a03198f0a14081006b3
    :1000f000031d562813080f06031d56288612812853
    :10010000061386178228193091008828fa3091004a
    :10011000c830920000000000000000000000000055
    :1001200000000000920b8a28910b88280800b2205a
    :10013000be200f0d0e39a138cf20f120e0208e0017
    :100140000321c7200800b2200e08cf20f120c720cd
    :100150000d1cb128be20a030cf20f120c7200d1cdf
    :10016000aa280800be200f0d0e39a038cf20f1209c
    :100170000d1cbd281008cf20f12008000a2105160b
    :100180001821051218210f211821051608000f212a
    :10019000051218210a2118210516182108009100be
    :1001a000083092000f21911f0512911b051618218e
    :1001b0000a2118210f21910d920bd2280516080053
    :1001c0000830920091010f21051618210a211821eb
    :1001d000910d1110051a1114920be3280f2111082b
    :1001e000080005160f2118210a2118210d10051edf
    :1001f0000d140f2108000f21051218210a211821c2
    :100200000f21051608000f21051618210a211821b3
    :100210000f2108008d1c05158d18051408008d1c74
    :1002200005118d18051008008d1008008d140800a8
    :0402300000000800c2
    :084000000200000000000000b6
    :02400e00f13f80
    :10420000280063002900200050006900650072004a
    :1042100072006500200043004f004c002c0020007d
    :104220006d00610072007300200032003000300029
    :1042300031002c0020005600200031002e003000fc
    :10424000530069007400650020007700650062007b
    :104250003a00200068007400740070003a002f00db
    :104260002f007700770077002e0063006f006c004e
    :1042700032003000300030002e006f007200670006
    :00000001ff
  1. PIC 16F84A and 7segment LED dispay
    By select in forum mel PIC BASIC Pro
    Last Post: - 21st November 2007, 21:01
  2. Slot Car timer with pic 16f84a
    By Snap in forum Serial
    Last Post: - 5th July 2007, 04:58
  3. ICSP using a 16F84a to program 24CXX
    By aftab in forum mel PIC BASIC
    Last Post: - 8th April 2007, 11:39
  4. send and receive data using pic 16f84a
    By PoTeToJB in forum Serial
    Last Post: - 25th February 2006, 14:47
