Line drivers & level restorers
Results 1 to 5 of 5
    I tried the Wiegand interface which is similar and maybe more difficult from the aspect that the line sits at +Vdd and drops low for 20 microseconds for every pulse transmitted.
    It worked OK for 20 meters and the spec's say for over 100. A friend of mine tested this to be true.
    So I believe with just an inverter or maybe a schmitt trigger even better resuts are to be expected.
    Also a resistor (470-1200 ohm) at the end line to +Vdd will help.
    Omaha, Nebraska USA
    So . . . a pull-up on the input at the receiving end?
    Russ
    N0EVC, xWB6ONT, xWN6ONT
    "Easy to use" is easy to say.
    Default Invertor
    I am currently driving from a pic pin through a 10k resistor to a pn2222a, base with the collector on ground and the emitter tied with 10K resistor to 5v. From the emitter out I am able to drive up to 300 ft to a similar circuit on the other end. In this configuration it is inverted and driven a good distance.
    The 7414 with the schmit triggered input will restore a very similar output to the other end, inverted from the single input on the '14.
    I am using this circuit configuration for PS/2 communication, works well.
    K
    Quote Originally Posted by RussMartin View Post
    Yes, that's right.
    hatchethand1000:
    I was a little confused by your configuration. Are you sure about this? It seems you have reverse biased the transistor.
  1. Darrel Taylor - Instant Interrupts-Problem 16F877A
    Last Post: - 31st December 2009, 14:19
  2. Replies: 0
    Last Post: - 3rd February 2009, 00:23
  3. Using input from Switch to control a loop
    Last Post: - 2nd February 2009, 06:02
  4. Loop with two motor and 2 sensors
  5. having problems with Hantronix 20x4 lcd
    By Rhatidbwoy in forum mel PIC BASIC Pro
    Last Post: - 22nd December 2005, 13:22
