16f883
Results 1 to 14 of 14
Thread: 16f883
    Oct 2006
    Edmonton AB Canada
    After inserting a ; into the inc file in front of the "offending" lines, I recompiled the code and with only the following line:
    @ DEVICE INTRC_OSC_NOCLOCKOUT
    As the ONLY text, I get the following:
    Warning [207] c:\progrm-blah-blah 54: found label after column1. DEVICE
    Error [122] c:\progrm-blah-blah 54: Illegal opcode (INTRC_OSC_NOCLOCKOUT)
    It almost looks like PBPro doesn't like this oscillator. ?
    The confusion continues.
    Gary
    I am using this line with the 16F883 with no other @ DEFINE lines or anything else, jus the one line.
    @ __config _CONFIG1, _INTRC_OSC_NOCLKOUT & _WDT_ON & _MCLRE_ON & _LVP_OFF & _CP_ON & _CPD_ON
    and I modified the file C:\PBP\16F883.INC
    ;*  16F883.INC                                                  *
    ;*  By        : Leonard Zerman, Jeff Schmoyer                   *
    ;*  Notice    : Copyright (c) 2009 microEngineering Labs, Inc.  *
    ;*              All Rights Reserved                             *
    ;*  Date      : 07/02/09                                        *
    ;*  Version   : 2.60                                            *
    ;*  Notes     :                                                 *
            NOLIST
        ifdef PM_USED
            LIST
            include 'M16F88x.INC'	; PM header
            device  pic16F883, intrc_osc_noclkout, wdt_on, mclr_on, lvp_off, protect_off
            XALL
            NOLIST
            LIST
            LIST p = 16F883, r = dec, w = -302
            INCLUDE "P16F883.INC"	; MPASM  Header
    ;       __config _CONFIG1, _INTRC_OSC_NOCLKOUT & _WDT_ON & _MCLRE_ON & _LVP_OFF & _CP_OFF
            NOLIST
            LIST
    Comment out the __config line and save the file.
    This works good for me.
    K
    Oct 2006
    Edmonton AB Canada
    Absolutely, almost fabulous.
    Everything works, up to the verify stage of the programmer without so much as a burp, but then:
    Code verify error at 0000
    3FFF should be 2828
    and on and on it goes 3FFF at 0001, 3FFF at 0002 etc etc.
    Erasing the target doesn't clear it.
    Quote Originally Posted by Meriachee View Post
    3FFF should be 2828
    I have had the same type of problems with the MElabs U2 programmer. The only way I could fix it was to reload the defaults to the programmer.
    meProg - Options - More Options - Set Options to Default
    I have not had this problem with other chips but the 16F883 seems to do it late and night or early in the morning. I went so far as to think my programmer was either out of date or broken. I purchased a new one with updated code and it did the same thing. Restoring defaults does seem to fix the strange errors with the U2.
    K
    Oct 2006
    Edmonton AB Canada
    Reset it a couple of times, and same issue. I am going to contact MeLabs over this one....
    Oct 2006
    Edmonton AB Canada
    Once again Charles comes through. It was the U2 programmer, indirectly. MeLabs updated the programmer code after the 883 chip was released. When the programmer was up-issued to 4.31 from 4.20 it worked exactly as it should. The firmware is current at #56.
    Thanks all for the help!
    Gary
    Gary
    If you use the
    @ DEVICE
    method,then you have to compile using PM. You are using MPASM to get the error and warning you have.
  1. 16F883 and Problems with HIGH statement
    By aaanekre in forum mel PIC BASIC Pro
    Last Post: - 29th October 2009, 02:09
  2. 16F883 Code Verify Problem
    By munromh in forum mel PIC BASIC Pro
    Last Post: - 19th February 2009, 12:47
  3. Using weak pull-up
    By Sharky in forum General
    Last Post: - 11th September 2007, 07:44
