18F4620 error
Results 1 to 7 of 7
Thread: 18F4620 error
    You have not looked around the forum much.
    http://www.picbasic.co.uk/forum/showthread.php?t=4751
    Why not post you code using using code tags?
    The code in its entirety is too long.
    Is the
    Include "Elapsed.bas"
    from DT?
    If so then this might be of help
    http://www.picbasic.co.uk/forum/show...5&postcount=18
    It has a version for the 18s.
    Thanks that did it.
  1. Using input from Switch to control a loop
    Last Post: - 2nd February 2009, 05:02
  2. Loop with two motor and 2 sensors
  3. Optimizing DIV
    Last Post: - 22nd September 2008, 04:58
  4. 16F88 Compile error
    By Toley00 in forum mel PIC BASIC Pro
    Last Post: - 2nd November 2005, 00:22
  5. Compiler/Assembler Error
    By LT_Pic in forum General
    Last Post: - 21st July 2005, 09:47
