18F4620 error
Results 1 to 7 of 7
Thread: 18F4620 error
    Default 18F4620 error
    Just learning the MPASM and 18F chips. I have one error, 'Symbol not previously defined (FSR)'
    What is that telling me? I can't find anything about FSR on the forum yet.
    Lots of stuff on the forum.
    http://www.google.com/custom?hl=en&c...0&ct=col1&cd=1
    Can you post your code and configs ?
    Attached is a zip file with the code.
    I need to start using Google to find info on this forum. When I use the forum's basic search for FSR, no results are found.
    Thanks in advance for your input.
    You have not looked around the forum much.
    http://www.picbasic.co.uk/forum/showthread.php?t=4751
    Why not post you code using using code tags?
    The code in its entirety is too long.
    Is the
    Include "Elapsed.bas"
    from DT?
    If so then this might be of help
    http://www.picbasic.co.uk/forum/show...5&postcount=18
    It has a version for the 18s.
  1. Using input from Switch to control a loop
    Last Post: - 2nd February 2009, 05:02
  2. Loop with two motor and 2 sensors
    Last Post: - 8th December 2008, 23:40
  3. Optimizing DIV
    Last Post: - 22nd September 2008, 04:58
  4. 16F88 Compile error
    By Toley00 in forum mel PIC BASIC Pro
    Last Post: - 2nd November 2005, 00:22
  5. Compiler/Assembler Error
    By LT_Pic in forum General
    Last Post: - 21st July 2005, 09:47
