character lcd 4 lines
Results 1 to 5 of 5
    jojokatada's Avatar
    jojokatada Guest
    Default character lcd 4 lines
    lcd 4 line
    hi anybody could help me how to display a 4 line character lcd.
    sample code
    pause 1
    lcdout $fe,1," Hello world", $fe,c0," hello again" ,fe,94,"welcome" fe,d4,"thank you"
    Dec 2003
    Wichita KS
    Hello Jojo,
    Chances are, you have two enable lines... one for the top 2 lines and one for the bottom two lines..
    Do a search on LCD in this forum... here is a example of a search
    http://www.picbasic.co.uk/forum/show...ghlight=LCD%2A
    Dwayne
    Ability to Fly:
    Pilots that are Flying:
    OR you forget to include
    DEFINE LCD_LINES 4
    Also try to increase you start up delay to 1 second.
    is your LCD display something??? at least on the 2 first line.
    I agree with DWAYNE, your LCD probably have 2 enable line if it's a 4X40 one.
    jojokatada's Avatar
    jojokatada Guest
    Default 4 lines lcd
    hi thank for help
    i am using 4x20 lcd
    It will be hard for us if you don't provide any info of your hardware connection, crystal speed and the PIC you're using.
    Let's assume you use the same connection in the PBP manual.
    Usually 4X20 LCD don't have 2 enable line. BUT some will need to place the 4 unused data bit to ground
    Try with this snippet and let us know.
    DEFINE OSC 4 ' Using 4 MHZ crystal
    DEFINE LCD_LINES 4 ' Using a 4 lines LCD
    pause 1000 ' wait LCD start-up delay
               ' P.S.: it can be higher or lower depending of
               '       the model you're using
    Start:
          lcdout $fe,  1,"Line 1",_
                 $fe,$c0,"Line 2",_
                 $fe,$94,"Line 3",_
                 $fe,$d4,"Line 4"
    Here:
         goto here
    this one should work.
  1. Is this code not initialising the LCD properly?
    By Platypus in forum mel PIC BASIC Pro
    Last Post: - 30th January 2010, 20:14
  2. Play with LCD on PICDEM
    Last Post: - 22nd August 2008, 17:56
  3. Need help with LCD number display.
  4. 4X20 TRULY LCD PPB lines 3 & 4
    Last Post: - 7th January 2007, 10:11
  5. having problems with Hantronix 20x4 lcd
    By Rhatidbwoy in forum mel PIC BASIC Pro
    Last Post: - 22nd December 2005, 13:22
