8192 baud
Results 1 to 6 of 6
Thread: 8192 baud
    I believe the Pickit2 supports atypical baud rates using the UART tool. It must be connected to VDD, GND, and the serial line, and should work with 2.5 to 5V levels...but I haven't tested this function yet
    Jun 2005
    Up the bush, Western Plains, NSW Au
    In the PBP manual under SEROUT2 it shows formula for given baudrate
    (1000000/8192)-20 = 102.07
    So, even tho I haven't tried it personally, I reckon that setting a mode of 102 should be pretty damn close to what you are looking for?? (maybe). Anyway, worth a play?
    Peter Moritz.
    New South Wales,
    Australia.
    Jul 2005
    If you are intending to read a odbi 8192 data stream I think u need to send some bytes to the ECM to get the 8192 baud data coming from the car. Excuse if this isnt about aldl car ecm communication, i'm looking for a way to interface my 18F4550 to a 95 Holden Commodore series II VR so that I can read the stream from the car (i beleive it's 22 bytes) in an 8n1 stream format...
    if anyone is working on a usb 8192 odb1 interface using a 18F4550 I would be overjoyed to chat with you about your progress..
    May 2007
    Republic Serbia
    Smile uart setup for adld
    Quote Originally Posted by muddy0409 View Post
    Use these external clock : 11.141 MHz
    And these defines:
    DEFINE HSER_SPBRG 84  ' 8192 Baud @ 11.141MHz, 0.0%
    You have nice UATR in 18F4550 and it will be do the job.
    Code is your side - see ADLD protocol on net - use the google.
    Have nice job.
    /Robert
    Last Post: - 8th March 2010, 21:58
  2. PIC 18f1220 EUSART Baud Rate Cache Problem
    By wklose99 in forum Off Topic
    Last Post: - 15th April 2008, 01:39
  3. Auto Baud Rate Detection
    By mytekcontrols in forum Serial
    Last Post: - 31st October 2005, 03:17
  4. PIC12F675, accuracy of baud rate with Internal Oscillator
    By Chris Mayhew in forum mel PIC BASIC Pro
    Last Post: - 31st August 2005, 23:41
  5. Baud Rate and Timing Calculator
    By picnaut in forum General
    Last Post: - 23rd January 2004, 17:48
