Easy HID Command -Response application
Results 1 to 26 of 26
    Dec 2006
    Phew, after a bit of headscratching ive got the DT_HID working with the DT_INTS-18 after having a bit of a fight with just getting the USB to recognise first (guess who used CLEAR in the wrong place LOL!!! )
    Once I had the USB recognised, I simple added my own interupt as per usual with the INTS-18 and it worked.
    One side effect with this is that in my main loop where the test counter i displayed was slow as it added 1 each cycle of the main loop is now racing along at a hell of a a faster rate wheras before it counted up at almost 1 per second. Not complaining though lol! as if this has kicked everything up a gear thats fine by me!
    Dec 2006
    Additional note to my post above on the super speed increase!
    Just gone back to my project and noticed that I ONLY get the super speedy respones WHEN then USB cable is plugged in! as soon as I remove it you can see the counters on the LCD drop to an almost crawl on the updates so im now completely confused!
  1. USB hid maker help please.
    By BobEdge in forum mel PIC BASIC Pro
    Last Post: - 3rd April 2013, 15:49
  2. i cant get 18f2550 work as HID
    By Ahmadabuomar in forum mel PIC BASIC Pro
    Last Post: - 13th October 2009, 17:39
  3. Unusual Interrupts Application Problem
    By Joe Rocci in forum mel PIC BASIC Pro
    Last Post: - 8th May 2009, 12:55
  4. Hid Maker FS Problems
    Last Post: - 24th April 2009, 22:27
  5. Making your own HID descriptor file
    By NL2TTL in forum mel PIC BASIC Pro
    Last Post: - 27th April 2005, 13:35
