Gremlins, or maybe the cats (if you have any).
Make sure you have plenty of capicitance on the VUSB pin. (.22uF to .47uF)
And have both a 10uF and 0.1uF capacitors on the Power Rails (VSS-VDD).
Plugged, RX_READY and TX_READY are just normal "Bits".
RX_READY indicates that data has been received. It should be cleared after use.
TX_READY indicates that the device is plugged in and the SIE is ready to accept data to send.Code:Main: IF RX_READY THEN ; USB data has been rcvd RX_READY = 0 ; clear the Ready flag USBIN 1, Buffer, Cnt, Main LCDOUT $FE,1,STR Buffer ENDIF
Code:IF TX_READY THEN ; USB is Ready to transmit TX_READY = 0 ; clear the Ready flag ADCIN 0, ADval ARRAYWRITE Buffer,[DEC4 ADval," "] USBOUT 1, Buffer, Cnt, TXfail TXfail: ENDIF GOTO Main
