Hi, Mehmet
In the Manual, LCDOUT Command Chapter, first page ...
You can find:
... if it's powered down and then powered back ....
ADD:
FLAGS = 0
The next LCDOUT Command found will re-initialise the LCD ...
That's all you have to do ...
Hi, Mehmet
You can find:
ADD:
FLAGS = 0
hi alain and ioannis.
i switched vcc of lcd and made the other pins zero.when pic waked up i added flags = 0
and now working fine.
thanks for your response
Hi, Ioannis
You're perfectly right on this point ... LOL !!!
Just need a PIC pin to drive a P Mosfet in the LCD Supply line ... eh !
I use a FQU11P06 ( I Pak case ) from Fairchild for my Lawn tractor onboard computer LCD ( The TRACTEUR program ... )
Note a BS250 should fit if using one of the lasts " Blue " displays ( Backlight current draw has been significantly reduced since old " green " displays ...
