16F684 - Capture - Timing - Counting
Results 1 to 2 of 2
    Aug 2007
    Default 16F684 - Capture - Timing - Counting
    I have done a bit with interrupts, but am new to the CCP feature. I am looking to use "capture" to measure a shaft revolution time. In addition, I need to count the shaft revolutions (1 pulse per rev) . Does the capture trigger an interrupt of some kind where I could increment a value to count the revolutions? I am looking for some direction. I intend to get the time capture going first, then add the counter if it is possible for both to be done. Thanks much for any input. Scott
    North Norfolk UK
    This application note from the microchip site will help you get started
    http://ww1.microchip.com/downloads/e...tes/00594B.PDF
    and you must apply those notes with respect to the device you are using by referencing the specific datasheet.
    have fun
  1. mS Timer
    By whmeade10 in forum mel PIC BASIC Pro
    Last Post: - 8th September 2020, 13:12
  2. Using hardware capture
    Last Post: - 25th March 2012, 06:52
  3. Interrupt RPM and Taylors Elapsed time on 18F4620
    Last Post: - 3rd February 2010, 17:12
  4. Measuring change of frequency with PIC
    By Aussie in forum mel PIC BASIC Pro
    Last Post: - 19th July 2007, 02:47
  5. continious counting process (capture)
    By asynch in forum General
    Last Post: - 17th February 2006, 08:42
