12F675 / MCLR use
Results 1 to 7 of 7
    Default 12F675 / MCLR use
    Who could explain me that ???
    This simple program is a flip-flop with button debouncing ... simple, eh !
    ( Button1 is on the low side - LOW level if pushed )
    When using MCLR ... output ( GPIO.2) is LOW at power-up ... Ok
    When disabling MCLR ( internal reset ) ... output is HIGH at power-up ... ???
    Instead to what it should be !!!
    Did I miss something ???
    ' Madproject
    'Anti rebond pour sauter à la perche ( ??? )
    ' 16F629 mode INTOSC @ 4 Mhz
    ' le 03/09/2009 139 Lignes
    ' CONFIG
     @    __CONFIG _INTRC_OSC_NOCLKOUT & _WDT_ON & _PWRTE_ON & _MCLRE_ON & _CP_OFF & _BODEN_ON
    DEFINE OSCCAL_1K 1
    DEFINE BUTTON_PAUSE 100
    ADCON0		= 0
    ANSEL		= 0
    CMCON		= 7
    VRCON 		= 0
    OPTION_REG.5 = 0
    OPTION_REG.7 = 1   	'Disable Pull-Ups
    Bouton1     VAR GPIO.0
    Bouton2     VAR GPIO.1
    Sortie      VAR GPIO.2
    'LedVisu     VAR GPIO.3			' Attention : Sortie PIC en C/O !!!
    LedVisu		 VAR GPIO.4
    'set         VAR GPIO.5
    x           VAR byte
    Delay		VAR byte
    GPIO 		= %00000011			'All pins LOW IF outputted - no startup bug.
    TRISIO 		= %00000011         'set GPIO.0 & GPIO.1 as inputs Others Output
    Attente: ' On attend !!!
        Delay = 0
       	BUTTON Bouton1,0,255,0,Delay,1,Action		' Poussoir à la masse enfoncé
    	PAUSE 10									' 10 ms entre scans
    	GOTO Attente   								' Non? : retour départ
    Action:	' On a enfoncé le bouton plus de 100 ms
       TOGGLE Sortie								' On inverse la sortie
       TOGGLE LedVisu
    Attente2: ' On attend que le bouton soit relâché ...
       Delay = 0
       BUTTON Bouton1,1,255,0,Delay,1,Attente		' Le bouton est il relaché ???
       GOTO Attente2									'  NON On boucle
    Never trust the state of any I/O on Power-Up - regardless of what the Datasheet says.
    Always preset your I/O's within your program to what you want them to be as one of the first things you do when initialising the PIC.
    Dec 2005
    From the datasheet...
    Figure 3-3 shows the diagram for this pin. The GP3 pin
    is configurable to function as one of the following:
    • a general purpose input
    • as Master Clear Reset
    and...
    bit 5 MCLRE: GP3/MCLR pin function select(5)
    1 = GP3/MCLR pin function is MCLR
    0 = GP3/MCLR pin function is digital I/O, MCLR internally tied to VDD
    and from your config fuses...
    _MCLRE_ON
    I think Alain is talking about GPIO.2 having an anomally when you configure GPIO.3 (MCLR) for different states. In theory it shouldn't effect that pin...
    Dec 2005
    Quote Originally Posted by Melanie View Post
    Ahhh! I misunderstood and thought he was trying to make GPIO.3 an output although I expected he would know better. I should have known better.
    What happens if the order of the TRISIO = and GPIO = statements are reversed?
    Wink
    Hi, Mel
    You do know the only one I trust in, is you, Mel ... ( Violins [ON] , Crooner [ON], Rose Petals drop [ON], Champagne [ON] ... )
    I just think you missed my two I/O Config lines ... ( Was late, eh ...)
    I must tell it ALSO affects GPIO.4 ... so, I have to try adding a little PAUSE after those CONFIG Lines, I smell a Power on little issue ... That make BUTTON read a low level when power up ...
    OR May be a " HIGH GPIO.0 " Command before the first BUTTON Command to ensure the High Level ...
    Testing a HIGH level for Button1 pressed is to also an idea ( some capacitive effects on GPIO.0 ??? ... despite it has no load but a Pullup resistor !) ...
    But, that's not something " normal " ...
    Talking Silicon bug ??? The end
    As I smelled ...
    Adding a little PAUSE 50 ( 40 is not enough ! ) just past the I/O config Lines solved the issue ...
    HIGH GPIO.0 didn't work ...
    Alain ( bug killer ...)
  1. How to MCLR by code for 16F877
    By fbestepe in forum mel PIC BASIC Pro
    Last Post: - 26th November 2014, 01:51
  2. MCLR as PIN on 12F675
    By rgregor in forum mel PIC BASIC Pro
    Last Post: - 28th October 2009, 10:46
  3. 12F675 MCLR directive MPASM
    By OLDSCHOOL in forum mel PIC BASIC Pro
    Last Post: - 4th May 2008, 02:29
  4. 12F675 won't reprogram or erase
    By modifyit in forum mel PIC BASIC Pro
    Last Post: - 19th May 2006, 06:07
  5. I/O pin and MCLR
    By Dwayne in forum FAQ - Frequently Asked Questions
    Last Post: - 15th July 2004, 11:52
