Not knowing how mains are wired where you are at but I will guess that there is a problem in the way they are wired at your place.
I had a similar problem at a customers place. A lot of high frequency "stuff" runs (similar to your smoke machine?). After spending time changing the power supply, adding capacitors etc I found the problem was bad or no earth grounds on most of the equipment. Several places the ground wire was connected to the machine but not to a ground rod creating several antennas going several directions.
I went though and fixed and or added the earth grounds and the problem was solved. The false alarms on their security system even stopped. Not sure about that one, just what I was told.
Might not be the problem, but just from a safety side it would be worth a look.
