Leds on/off
Results 1 to 17 of 17
Thread: Leds on/off
    Default Leds on/off
    Hello forum friends,
    I have 4 buttons connected to PORTB and 4 LEDs to PORTB, I turn on and off with the same button for the LED but independently, with this code does not work properly any suggestions?.
    start:
    IF PORTB.0=0 then
        HIGH PORTB.4
        WHILE PORTB.0=0 : Wend : pause 50
    IF PORTB.0=0 then
        LOW PORTB.4
    iF PORTB.1=0 then
        HIGH PORTB.5
    IF PORTB.1=0 then
        LOW PORTB.5
    iF PORTB.2=0 then
        HIGH PORTB.6
    IF PORTB.2=0 then
        LOW PORTB.6
    iF PORTB.3=0 then
        HIGH PORTB.7
    IF PORTB.3=0 then
        LOW PORTB.7
    goto start
    How do you have the TRIS set for this?
    TRIS Series I have not configured but the code does not work well.
    You will need to set the TRIS for the port. That will tell what pins are input or out puts.
    Try adding this near the top of your code.
    TRISB = %00001111
    That will make PORTB 0 to 3 an input and 4 to 7 an output.
    Hello mackrackit,
    I have added TRISB =% 00001111 but as usual the code does not work well.
    Leonardo
    TRISB = %00001111
    Can you post the whole code and exactly what is it doing or not doing?
    iF PORTB.1=0 then
        HIGH PORTB.5
    Why not use Toggle ?
    IF PORTB.1=0 then
        toggle PORTB.5
    Do not know what you are doing with PORTB.0 or why it is always low in each
    if then loop . . . or is that a copy paste error, and is low only in the first loop ?
    maybe should be PortB.1 in this loop ? Select case could tidy this up even more . . .
    Jan 2006
    Istanbul
    If you are simulating it as seen in your schematic, then the simulator might be giving false simulation because you do not have resistors on the leds.
    I say this is 98% possibility of the error you are getting.
    Talking the car without engine ...
    I do not remember the 16F84 had an internal oscillator ...
    none aboard the ( censored ) simulation ...
    But I'm just getting 53 ...
    PS: Ahhhhh ... Da Vinci Code !!!!
    May 2007
    Republic Serbia
    16F84 and 16F84A do not have internal OSC...
    Jan 2006
    Istanbul
    Quote Originally Posted by phoenix_1 View Post
    On his simulator, it is not required to connect crystal or resonator etc.
    It will run normally as if those were connected.
    Hi, Sayzer
    I do not want to use sims ... lol
    BTW :
    IF PORTB.0=0 then
    HIGH PORTB.4
    IF PORTB.0=0 then
    LOW PORTB.4
    This kind of structure can't work properly ... as the second part never can be reached !!! ( or toggling button in less than 1µs ... )
    Button state AND its corresponding output state must be tested at the same time ... to take the appropriate action.
    Talking
    Sorry ...
    was not 1µs but 50 ms ...
    but result is the same !!!
    chatchai's Avatar
    chatchai Guest
    Red face I am speek Thai and my english very bad... but my example..
    ' Test I/O Ports Input and Output
    SW1 var PORTB.0
    SW2 var PORTB.1
    SW3 var PORTB.2
    SW4 var PORTB.3
    LED1 VAR PORTD.0
    LED2 VAR PORTD.1
    LED3 VAR PORTD.2
    LED4 VAR PORTD.3
    i var byte
    DEFINE OSC 48
    '------- Initial IO Ports -------
    TRISB = $FF
    TRISD = 0
    CMCON = 0
    ADCON1 = 7
    '------- Main Function -------
    LED1 = SW1
    LED2 = SW2
    LED3 = SW3
    LED4 = SW4
    Jan 2008
    Try this
    start:
    IF PORTB.0=0 then
        toggle PORTB.4
    IF PORTB.1=0 then
        toggle PORTB.5
        WHILE PORTB.1=0 : Wend : pause 50
    IF PORTB.2=0 then
        toggle PORTB.6
        WHILE PORTB.2=0 : Wend : pause 50
    IF PORTB.3=0 then
        toggle PORTB.7
        WHILE PORTa.3=0 : Wend : pause 50
    goto start
    May 2008
    Italy
    Place a 330 ohms in series to each leds (as suggested in previuos post), and use Toggle command (as suggested in previuos post).
    start:
    Pause 50
    IF PORTB.0=0 then
        Toggle PORTB.4
    IF PORTB.1=0 then
        Toggle PORTB.5
    IF PORTB.2=0 then
        Toggle PORTB.6
    IF PORTB.3=0 then
        Toggle PORTB.7
    HoldLoop:
    If PortB & %00001111 != 15 then HoldLoop
    goto start
    Al.
    Thanks Aratti
    Quote Originally Posted by aratti View Post
    start:
    Pause 50
    IF PORTB.0=0 then
        Toggle PORTB.4
    IF PORTB.1=0 then
        Toggle PORTB.5
    IF PORTB.2=0 then
        Toggle PORTB.6
    IF PORTB.3=0 then
        Toggle PORTB.7
    HoldLoop:
    goto start
    Al.
  1. Run a string of LEDs from the mains
    Last Post: - 1st October 2009, 19:55
  2. Replies: 14
    Last Post: - 26th April 2007, 16:12
  3. Using LEDs as light sensors
    Last Post: - 30th December 2006, 23:19
  4. controlling leds with the switches
    By ilteris in forum mel PIC BASIC Pro
    Last Post: - 12th October 2005, 22:02
  5. Replies: 5
    Last Post: - 16th February 2005, 12:57
