Hello Unregistered ,
Originally Posted by hatchethand1000 Has anyone see a change on the SERIN command with ver 2.60 upgrade? I had this command working fine with v2.50a and now it will not work on 2.6 Any ideads? the ON9600 seems to be the issue. Code: Serin PORTC.5,ON9600,B0 Thanks, Kevin Is this new code or old code that worked with 2.5? Did you remember to include modefs.bas? Can you find the new thread button?
Dave Always wear safety glasses while programming.
Hi all, I resolved the issue. I just had to remove the brackets when using SERIN. Aratti was right. Thanks for the help!
Forum Rules
