SERIN and SEROUT
Results 1 to 11 of 11
    Sep 2009
    Brisbane, Australia
    Question SERIN and SEROUT
    Hi all,
    First post here, hopefully one of many (helping as well as getting help)
    I have a question that I'm sure has a very simple answer, but I'm having trouble with it. I've got a situation where I need to use multiple PICs in a project (I'm working with the PIC16F628A on a 4MHz XTAL) and I need them to be able to send data to one another. One will only send data and one will only receive data. Nothing fancy, it only needs to send a single digit number.
    What I'd like to know is, what is some basic code to put on PIC A and PIC B to get PIC A to send numbers 0 to 3 via SEROUT and have PIC B recognise those numbers and, say, light up an appropriate LED. Currently I'm using the following code:
    'PIC A (Sender)
    INCLUDE "modedefs.bas"
    x VAR byte
    FOR x = 0 to 3
    SEROUT PORTB.0, T2400, [x]
    PAUSE 1000
    NEXT
    GOTO main
    'PIC B (receiver)
    x VAR byte
    SERIN PORTB.0, T2400, [x]
    IF x = 0 THEN HIGH PORTB.1
    IF x = 1 THEN HIGH PORTB.2
    IF x = 2 THEN HIGH PORTB.3
    IF x = 3 THEN HIGH PORTB.4
    GOTO main
    I'm aware it may also be a wiring issue... I just have a straight wire (I'm breadboarding this first) going from PORTB.0 on PIC A to PORTB.0 on PIC B.
    Anyone have some advice?
    Thanks in advance!
    Hello CumQuaT,
    Welcome to the forum.
    Quote Originally Posted by CumQuaT View Post
    You could start by telling us what kind of problem you are having . . . DOA . . . ?
    A couple of things, DEFINE OSC 4 near the top of your code.
    If you are not using analog on PortA add cmcon = 7 to disable the comparators there so it doesn't trip you later.
    Set up your Ports as high or low before setting your TRIS registers, and do not skip setting those.
    'a config statement should go here unless default config is just right
        cmcon = 7
        PortA = 0
        PortB = 0 set all output latches low
        TrisA = %00000000 'set PortA as all outputs
        TrisB = %11100000 '5,6,7 as inputs all others as outputs
        ' . . . . your code goes here
        goto Main
    EDIT: Serial data, True idles high, and wants a pull up resistor on the data line to 5v +
    Inverted idles LOW and wants a resistor pulling to logic LOW or ground.
    Sep 2009
    Brisbane, Australia
    Default Reply
    Hi! Thanks for the warm welcome!
    I actually described precisely what my problem is. The code I have with the connections I have isn't transmitting or receiving single numbers. I am also not using porta at all in my code.
    May 2008
    Italy
    See page 131 of PBP manual. Since you have used bracket pic is waiting for QUALIFIER first. Remove brackets from SERIN.
    SERIN PORTB.0,T2400,x
    Follow Joe advice on the setting even if you don't use PortA.
    All the above and
    You also have the "grounds" connected? Two wires are needed.
    Sep 2009
    Brisbane, Australia
    Default reply
    You mean the grounds to the PIC? As in VSS? Or are there grounds required in regards to wiring the two pics together in serial?
    I must be getting senile . . . single numbers . . . or anything usable (DATA), if you send a string does that show up ? Or do you get nothing at all ? Do your Pics do anything? Do you have a heartbeat LED on them to ascertain they are actually working?
    As mentioned above serial is 2 wire signal and ground, coax or twisted works fine, (doorbell wire makes for cheap twisted pair).
    Question: Are you using a resonator / crystal / or INternal RC Oscillator ? Do the default config statements located in the 16F628A.inc file in the PBC root directory agree with what you are trying to use? Are you using PBC or PBP ?
    Default Serin Command
    Has anyone see a change on the SERIN command with ver 2.60 upgrade?
    I had this command working fine with v2.50a and now it will not work on 2.6
    Any ideads? the ON9600 seems to be the issue.
    Serin PORTC.5,ON9600,B0
    Kevin
    Quote Originally Posted by hatchethand1000 View Post
    Kevin
    Is this new code or old code that worked with 2.5?
    Did you remember to include modefs.bas?
    Can you find the new thread button?
  1. PIC16f877 code crosses boundary @800h
    By inventosrl in forum mel PIC BASIC Pro
    Last Post: - 6th April 2009, 22:03
  2. Advice-scrutiny for my serial controller
    Last Post: - 13th December 2008, 17:11
  3. Help with serin, serout, Manchester encoding
    Last Post: - 5th April 2007, 13:31
  4. Serial interface with RFID reader
    By brid0030 in forum Serial
    Last Post: - 23rd January 2007, 06:23
  5. SerIn and SerOut
    By Dwayne in forum FAQ - Frequently Asked Questions
    Last Post: - 21st July 2004, 15:54
